Chinese 2.8" TFT LCD Display Touch Screen Help
I bought a cheap LCD screen for a project I'm working on to get my feet wet with programming LCD touch screens before buying a "full-size" screen. But i can not find any libraries or code to get it to display anything. Ive downloaded the new ILI9341 library along with 4-5 other ones and can not get it to display or do anything.
Im using an UNO with THIS display. i would prefer to use my mega but this one says it is only for the UNO. I tried the links on the eBay page for getting it to work but they didn't seem to help.
here are three codes I'm trying to run that upload but don't display. Im extremely new to this and i had a fellow programmer give me a hand but can not figure it out.
Any help would be greatly appreciated.
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// you can also just connect RESET to the arduino RESET pin
#define LCD_RESET A4
//Duemilanove/Diecimila/UNO/etc ('168 and '328 chips) microcontoller:
// Color definitions
#define BLACK           0x0000
#define BLUE            0x001F
#define RED             0xF800
#define GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
#include "TFTLCD.h"
TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
void setup(void) {
  Serial.println("8 Bit LCD test!");
  uint16_t identifier = tft.readRegister(0x0);
if (identifier == 0x9325) {
   Serial.println("Found ILI9325");
} else if (identifier == 0x9328) {
   Serial.println("Found ILI9328");
   Serial.print("Unknown driver chip ");
   Serial.println(identifier, HEX);
   while (1);
  tft.reset();
  tft.initDisplay();
  testtext(RED);
  delay(2000);
  testlines(CYAN);
  testfastlines(RED, BLUE);
  testdrawrects(GREEN);
  testfillrects(YELLOW, MAGENTA);
  tft.fillScreen(BLACK);
  testfillcircles(10, MAGENTA);
  testdrawcircles(10, WHITE);
  testtriangles();
  testfilltriangles();
  testRoundRect();
  testFillRoundRect();
void loop(void) {
  for (uint8_t rotation=0; rotation<4; rotation++) {
    tft.setRotation(rotation);
    testtext(RED);
void testFillRoundRect() {
  for (uint16_t x=tft.width(); x > 20 ; x-=6) {
    tft.fillRoundRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, x/8,  tft.Color565(0, x, 0));
void testRoundRect() {
  for (uint16_t x=0; x < tft.width(); x+=6) {
    tft.drawRoundRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, x/8, tft.Color565(x, 0, 0));
void testtriangles() {
  for (uint16_t i=0; i<tft.width()/2; i+=5) {
    tft.drawTriangle(tft.width()/2, tft.height()/2-i,
                     tft.width()/2-i, tft.height()/2+i,
                     tft.width()/2+i, tft.height()/2+i, tft.Color565(0, 0, i));
void testfilltriangles() {
  for (uint16_t i=tft.width()/2; i>10; i-=5) {
    tft.fillTriangle(tft.width()/2, tft.height()/2-i,
                     tft.Color565(0, i, i));
                     tft.width()/2+i, tft.height()/2+i, tft.Color565(i, i, 0));
void testtext(uint16_t color) {
  tft.setCursor(0, 20);
  tft.setTextColor(color);
  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextSize(2);
  tft.println(1234.56);
  tft.setTextSize(3);
  tft.println(0xDEADBEEF, HEX);
void testfillcircles(uint8_t radius, uint16_t color) {
  for (uint16_t x=radius; x < tft.width(); x+=radius*2) {
    for (uint16_t y=radius; y < tft.height(); y+=radius*2) {
      tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
  for (uint16_t x=0; x < tft.width()+radius; x+=radius*2) {
    for (uint16_t y=0; y < tft.height()+radius; y+=radius*2) {
      tft.drawCircle(x, y, radius, color);
void testfillrects(uint16_t color1, uint16_t color2) {
 for (uint16_t x=tft.width()-1; x > 6; x-=6) {
   //Serial.println(x, DEC);
   tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1);
   tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2);
void testdrawrects(uint16_t color) {
   tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
void testfastlines(uint16_t color1, uint16_t color2) {
   for (uint16_t y=0; y < tft.height(); y+=5) {
     tft.drawHorizontalLine(0, y, tft.width(), color1);
   for (uint16_t x=0; x < tft.width(); x+=5) {
     tft.drawVerticalLine(x, 0, tft.height(), color2);
void testlines(uint16_t color) {
     tft.drawLine(0, 0, x, tft.height()-1, color);
   for (uint16_t y=0; y < tft.height(); y+=6) {
     tft.drawLine(0, 0, tft.width()-1, y, color);
     tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
     tft.drawLine(tft.width()-1, 0, 0, y, color);
     tft.drawLine(0, tft.height()-1, x, 0, color);
     tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
     tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
     tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
void testBars() {
  uint16_t i,j;
  for(i=0; i < tft.height(); i++)
    for(j=0; j < tft.width(); j++)
      if(i>279) tft.writeData(WHITE);
      else if(i>239) tft.writeData(BLUE);
      else if(i>199) tft.writeData(GREEN);
      else if(i>159) tft.writeData(CYAN);
      else if(i>119) tft.writeData(RED);
      else if(i>79) tft.writeData(MAGENTA);
      else if(i>39) tft.writeData(YELLOW);
      else tft.writeData(BLACK);
// Touch screen library with X Y and Z (pressure) readings as well
// as oversampling to avoid 'bouncing'
// This demo code returns raw readings, public domain
#include <stdint.h>
#include "TouchScreen.h"
#define YP A2  // must be an analog pin, use "An" notation!
#define XM A3  // must be an analog pin, use "An" notation!
#define YM 8   // can be a digital pin
#define XP 9   // can be a digital pin
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
void setup(void) {
void loop(void) {
  // a point object holds x y and z coordinates
  TSPoint p = ts.getPoint();
  // we have some minimum pressure we consider 'valid'
  // pressure of 0 means no pressing!
  if (p.z > ts.pressureThreshhold) {
     Serial.print("X = "); Serial.print(p.x);
     Serial.print("\tY = "); Serial.print(p.y);
     Serial.print("\tPressure = "); Serial.println(p.z);
  delay(100);
this is a long code so i broke it up in this and the next post
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
// For the Adafruit shield, these are the default.
#define TFT_DC 9
#define TFT_CS 10
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// If using the breakout, change pins as desired
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
  Serial.println("ILI9341 Test!");
  tft.begin();
  // read diagnostics (optional but can help debug problems)
  uint8_t x = tft.readcommand8(ILI9341_RDMODE);
  Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDMADCTL);
  Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDPIXFMT);
  Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDIMGFMT);
  Serial.print("Image Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDSELFDIAG);
  Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
  Serial.println(F("Benchmark                Time (microseconds)"));
  Serial.print(F("Screen fill              "));
  Serial.println(testFillScreen());
  Serial.print(F("Text                     "));
  Serial.println(testText());
  delay(3000);
  Serial.print(F("Lines                    "));
  Serial.println(testLines(ILI9341_CYAN));
  Serial.print(F("Horiz/Vert Lines         "));
  Serial.println(testFastLines(ILI9341_RED, ILI9341_BLUE));
  Serial.print(F("Rectangles (outline)     "));
  Serial.println(testRects(ILI9341_GREEN));
  Serial.print(F("Rectangles (filled)      "));
  Serial.println(testFilledRects(ILI9341_YELLOW, ILI9341_MAGENTA));
  Serial.print(F("Circles (filled)         "));
  Serial.println(testFilledCircles(10, ILI9341_MAGENTA));
  Serial.print(F("Circles (outline)        "));
  Serial.println(testCircles(10, ILI9341_WHITE));
  Serial.print(F("Triangles (outline)      "));
  Serial.println(testTriangles());
  Serial.print(F("Triangles (filled)       "));
  Serial.println(testFilledTriangles());
  Serial.print(F("Rounded rects (outline)  "));
  Serial.println(testRoundRects());
  Serial.print(F("Rounded rects (filled)   "));
  Serial.println(testFilledRoundRects());
  Serial.println(F("Done!"));
void loop(void) {
  for(uint8_t rotation=0; rotation<4; rotation++) {
    testText();
unsigned long testFillScreen() {
  unsigned long start = micros();
  tft.fillScreen(ILI9341_BLACK);
  tft.fillScreen(ILI9341_RED);
  tft.fillScreen(ILI9341_GREEN);
  tft.fillScreen(ILI9341_BLUE);
  return micros() - start;
unsigned long testText() {
  tft.setCursor(0, 0);
  tft.setTextColor(ILI9341_WHITE);  tft.setTextSize(1);
  tft.setTextColor(ILI9341_YELLOW); tft.setTextSize(2);
  tft.setTextColor(ILI9341_RED);    tft.setTextSize(3);
  tft.println();
  tft.setTextColor(ILI9341_GREEN);
  tft.setTextSize(5);
  tft.println("Groop");
  tft.setTextSize(2);
  tft.println("I implore thee,");
  tft.setTextSize(1);
  tft.println("my foonting turlingdromes.");
  tft.println("And hooptiously drangle me");
  tft.println("with crinkly bindlewurdles,");
  tft.println("Or I will rend thee");
  tft.println("in the gobberwarts");
  tft.println("with my blurglecruncheon,");
  tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
  unsigned long start, t;
  int           x1, y1, x2, y2,
                w = tft.width(),
                h = tft.height();
  x1 = y1 = 0;
  y2    = h - 1;
  start = micros();
  for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
  x2    = w - 1;
  for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
  t     = micros() - start; // fillScreen doesn't count against timing
  x1    = w - 1;
  y1    = 0;
  y2    = h - 1;
  start = micros();
  x2    = 0;
  t    += micros() - start;
  x1    = 0;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = w - 1;
  x1    = w - 1;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = 0;
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
  unsigned long start;
  int           x, y, w = tft.width(), h = tft.height();
  start = micros();
  for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
  for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
  int           n, i, i2,
                cx = tft.width()  / 2,
                cy = tft.height() / 2;
  n     = min(tft.width(), tft.height());
  start = micros();
  for(i=2; i<n; i+=6) {
    i2 = i / 2;
    tft.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
  unsigned long start, t = 0;
  int           n, i, i2,
                cx = tft.width()  / 2 - 1,
                cy = tft.height() / 2 - 1;
  for(i=n; i>0; i-=6) {
    i2    = i / 2;
    start = micros();
    tft.fillRect(cx-i2, cy-i2, i, i, color1);
    // Outlines are not included in timing results
    tft.drawRect(cx-i2, cy-i2, i, i, color2);
  return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
  int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
  start = micros();
  for(x=radius; x<w; x+=r2) {
    for(y=radius; y<h; y+=r2) {
unsigned long testCircles(uint8_t radius, uint16_t color) {
  int           x, y, r2 = radius * 2,
                w = tft.width()  + radius,
                h = tft.height() + radius;
  // Screen is not cleared for this one -- this is
  // intentional and does not affect the reported time.
  start = micros();
  for(x=0; x<w; x+=r2) {
    for(y=0; y<h; y+=r2) {
unsigned long testTriangles() {
  int           n, i, cx = tft.width()  / 2 - 1,
  n     = min(cx, cy);
  start = micros();
  for(i=0; i<n; i+=5) {
    tft.drawTriangle(
      cx    , cy - i, // peak
      cx - i, cy + i, // bottom left
      cx + i, cy + i, // bottom right
      tft.color565(0, 0, i));
unsigned long testFilledTriangles() {
  int           i, cx = tft.width()  / 2 - 1,
  start = micros();
  for(i=min(cx,cy); i>10; i-=5) {
    start = micros();
    tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      tft.color565(0, i, i));
    tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      tft.color565(i, i, 0));
  return t;
unsigned long testRoundRects() {
  int           w, i, i2,
  w     = min(tft.width(), tft.height());
  start = micros();
  for(i=0; i<w; i+=6) {
    i2 = i / 2;
    tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
  int           i, i2,
  start = micros();
  for(i=min(tft.width(), tft.height()); i>20; i-=6) {
    i2 = i / 2;
    tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
Look at this article:
Works for Mega. Just follow the instructions.
i tried that originally and could not get it to work with my UNO. Ill try it with my mega but i don't have high hopes.
so surpassingly i got the code to run on the arduino MEGA but its still not displaying anything.
here is a serial print out of it running i added to check if it was getting stuck. So i know the code "works" but its still not displaying.
8 Bit LCD test!
finished first code
finshed second code
text
first display code
lines one
lines fast
rects
fill reqs
fill circles
draw circles
first triangle
second triangle
second square
first square
finished setup
running loop
text
and here is the code I'm running.
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define	BLUE            0x001F
#define	RED             0xF800
#define CYAN            0x07FF
#include "TFTLCD.h"
void setup(void) {
  tft.reset();
  Serial.println("finished first code");
  tft.initDisplay();
  Serial.println("finshed second code");
  testtext(RED);
  delay(2000);
  Serial.println("first display code");
  testlines(CYAN);
  testtriangles();
  testRoundRect();
  Serial.println("finished setup");
void loop(void) {
  Serial.println("running loop");
    testtext(RED);
  Serial.println("first square");
  Serial.println("second square");
  Serial.println("first triangle");
  Serial.println("second triangle");
   Serial.println("text");
  tft.setTextSize(1);
  tft.setTextSize(2);
  tft.setTextSize(3);
   Serial.println("fill circles");
  Serial.println("draw circles");
  Serial.println("fill reqs");
  Serial.println("rects");
   Serial.println("lines fast");
   Serial.println("lines one");
void testBars() {
  uint16_t i,j;
