and to try to print to the serial monitor the messages you see, but it's not working.
I've tried by using Serial1 instead of Serial and it's working, but after that, upload a new sketch become impossible unless of a trick (that is, remove the USB cable while pushing the reset button, than attach the USB cable, then launch the upload, and after i recognize the uploading is starting release the reset button...in short a mess )
Have someone encountered in this issue and have found a solution? It's possible that the firmware on the SAMD11 must be updated?
Hi Sterretje,
first, thank you so much for your answer.
Here my answers:
Thinary Development Board
The error message is avrdude: jtagmkII_getsync(): sign-on command: status -1
I've already use the Thinary package. As i sai, i've alredy load a sketch, but with the Serial1 instead of Serial.But now it's impossibile to upload a new sketch.
Thank you
