I build an obstacle avoiding robot using tank treads and a tamiya twin motor gear box. The chip gets super hot right away this is my first project. if any one can help that would be great i am using a 2s lipo for power
#include <AFMotor.h> //import your motor shield library #define trigPin 12 // define the pins of your sensor #define echoPin 13
AF_DCMotor motor1(1,MOTOR12_8KHZ); // set up motors.
AF_DCMotor motor2(2, MOTOR12_8KHZ);
Serial.begin(9600); // begin serial communitication
Serial.println("Motor test!");
pinMode(trigPin, OUTPUT);// set the trig pin to output (Send sound waves)
pinMode(echoPin, INPUT);// set the echo pin to input (recieve sound waves)
motor1.setSpeed(105); //set the speed of the motors, between 0-255
motor2.setSpeed (105);
long duration, distance; // start the scan
digitalWrite(trigPin, LOW);
delayMicroseconds(2); // delays are required for a succesful sensor operation.
digitalWrite(trigPin, HIGH);
delayMicroseconds(10); //this delay is required as well!
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;// convert the distance to centimeters.
if (distance < 25)/*if there's an obstacle 25 centimers, ahead, do the following: */ {
Serial.println ("Close Obstacle detected!" );
Serial.println ("Obstacle Details:");
Serial.print ("Distance From Robot is " );
Serial.print ( distance);
Serial.print ( " CM!");// print out the distance in centimeters.
Serial.println (" The obstacle is declared a threat due to close distance. ");
Serial.println (" Turning !");
motor1.run(FORWARD); // Turn as long as there's an obstacle ahead.
motor2.run (BACKWARD);
if i lower the gear ratio would that have the same effect? also did you see the part in the code about one motor being 64khz and the other was 8khz, what was that all about?
when i set the motor speed below 90 or so it hums or buzzes but does not move. The motors came with the Tamiya twin motor gear box.
the operating range is 1.5 to 3V
current .66 with a load
2.20 is the stall current
1.5v in the nominal value.
Thank you for your help. I appreciate it.
Joe
Thank you for all your advise. I did not realize the motor shield did not change the voltage to the motor. So I will try again with less power. Can I use the 7.2V lipo to power the Arduino itself? or am i asking for trouble?
Thanks
Joe
