Choice of wireless module
Hi there,
I need to communicate readings of intensity values from a color sensor to my PC using arduino. I want to choose a wireless module between X Bee and Bluetooth. I don't need long range of distance and I want high transmission data rate.Moreover I want a cheaper one.I think Bluetooth is better choice because almost all PCs support Bluetooth. But I heard it is difficult to configure Bluetooth using arduino. Configuring X Bee is quite easy. What you think is good to go with?
Thanks in advance!!
You need to define what you meanby a high data rate. Neather are good at this.
If you get an XBee shield, you can plug in XBee modules as well as RN-XV wifi and
BT Bee modules, so you have a range of options.
I have hard time to connect high transmission data rate with color sensor.
What type color sensor?
What type color object you try to measure?
sonnyyu:
Try harder then.
There are a lot of colour to frequency sensors and the OP might be trying to send the output frequency.
Grumpy_Mike:
sonnyyu:
Try harder then.
maybe you could show us how to send output frequency of color sensor directly to PC via X Bee or Bluetooth. :wink:
I'm using TCS3210(Light to frequency convertor). I need data rate sufficient enough to transmit values of 16 sensors without much noticeable delay. I need a compact design and a cheaper one.
Thanks!
1 sample per second per sensor
the bits is needed for one sensor is 8bits (R), 8bits (G), 8bits (B), 8bits (Sensor address).
the total bits per sensor= 32 bits
The total data rate= 32*16= 512 bits/sec
It is not high data rate.
