hi
i want to make sensor of image its for measuring distance .
in your minds which sensor is better for making that?
vishkas:
You can use Ultrasonic. I hope it is the right choice
What is the field of view of ultrasonic sensors? I am looking for a sensor that can measure the size of about 20 to 70 cm with an accuracy of 2 cm Have a completely linear field of view
What kind of precision are you expecting? Commercial weight bridges can do 0.1%.
To get the weight of a truck by how much it pushes down on its springs you will need sensors at all suspension points. Besides the hysteresis in the springs and shocks, you have to make sure the tires are always inflated to the same pressure as that will also affect the height.
wvmarle:
Accuracy of measuring 5% of the total weight of the truck
