choose the values of the variables
Hello, I'm new in programming and Arduino.
I use a Step motor, an Arduino MEGA 2560 and a SMCI47-S-2 Nanotec.
I would like to know how I can choose different values, like in my program,
I can choose right 'r' or left 'l' and now I would like to choose the stepNumber.
I would like to write in serial for exemple " 1000,r" to say 1000 step and direction right.
this is my code :
int pinBouton;
int stateButton;
int pinLedG = 10; //Led Green
int pinLedR = 11; //Led Red
int pin31 = 31; //Start/Reset
int pin32 = 32; //Step Motor
int pin36 = 36; //Clock
int e=0; //RETURN TO RIGHT AFTER HIT BUTTON
int i=0; //FOR RIGHT
int j=0; //FOR LEFT
int serialData = 0;// data and serial data are just variables to hold information.
int data = 0;
int displacement = 10 ; // mm //CHOOSE YOUR DISPLACEMENT TO THE LEFT IN millimeter
int stepNumberToRight = 1000; // Step number To Right
int stepNumberToLeft = 3000; //Step number To Left
bool endswitch=false;
int incomingByte;
// the setup routine runs once when you press reset:
void setup(){
Serial.begin(9600); //start talking with the computer. 9600 just tells the rate.
Serial.println("*** Program start ");
Serial.print("Name of this program is :");
Serial.println(" sketch_mar06a");
Serial.println("
TAPE on 'r' going to the RIGHT or TAPE on 'l' going to the LEFT ***");
// initialize the digital pin as an output.
pinMode(pinBouton, INPUT); //mode lecture pour le bouton
pinMode(pinLedG, OUTPUT); //mode écriture pour led1
pinMode(pinLedR, OUTPUT); //mode écriture pour led2
pinMode(pin31, OUTPUT); //mode ecriture pour pin31
pinMode(pin32, OUTPUT); //mode ecriture pour pin32
pinMode(pin36, OUTPUT); //mode ecriture pour pin36
attachInterrupt(digitalPinToInterrupt(3),stopmotor,FALLING);
Serial.flush();
while (Serial.available() >0) //Serial.available will tell the board to look at the information being sent to it through the serial port.
incomingByte = Serial.read();
//Step motor going to RIGHT (r=114 en ASCII)
{if(incomingByte == 'r')
digitalWrite(pin31,LOW); //pin31 0V START_RESET
digitalWrite(pin32, HIGH); // RIGHT
digitalWrite(pinLedG,HIGH);
while (j<stepNumberToRight){
digitalWrite(pin31,HIGH); //pin31 +5V FRONT MONTANT
digitalWrite(pin36,LOW); //pin36 0V
delay(2);
digitalWrite(pin36,HIGH); //pin36 +5V
delay(2);
j=j+1;
//Serial.println("BOUCLE 4");
digitalWrite(pin31,LOW); //pin31 +5V START_RESET
Serial.println("BOUCLE 1 RIGHT");}
delay(20); // temps d'attente si supérieur a 20 ça ne fonctionne pas
//Step motor going to LEFT (l=108 en ASCII)
{if(incomingByte == 'l')
digitalWrite(pin31,HIGH); //pin31 +5V START_RESET
digitalWrite(pin32, LOW); // LEFT
while (i<stepNumberToLeft){
delay(2);
delay(2);
i=i+1;
//Serial.println("BOUCLE 3");
Serial.println("BOUCLE 0 LEFT");
//digitalWrite(pin31,HIGH);
//delay(20); // temps d'attente si supérieur a 20 ça ne fonctionne pas
//digitalWrite(pin31,LOW);
void stopmotor(){
i=stepNumberToLeft;
endswitch=true;
digitalWrite(pin32,HIGH); //RIGHT
while(e<500){ /// temps de retour de charriot vers la droite
delay(2);
delay(2);
e=e+1;
Serial.println("BOUCLE 5"); //BOUCLE 5
Serial.println("TOUCH");
Serial.println("BOUCLE 8"); //BOUCLE 8
If you want, you can answer in French or English :wink:
Thanks
So, what is the problem? If you have some option other than nothing selected as the line ending in the Serial Monitor application, the Serial Monitor application will supply an end-of packet marker.
You find and read Robin2's Serial Input Basics - Updated thread, and read and store the data until the end of packet marker arrives. When it does, you parse and use the stored data and erase the stored data.
Ok thank, I'm going to read this topic
I would to know "how I can choose the value to stepNumber myself in the part of Serial monitor" ?
valleevi:
Read the topic suggested to see how to receive and parse the data from the Serial monitor
Links ...
Serial Input Basics
Stepper Motor Basics
Simple Stepper Code
To make it easy for people to help you please modify your post and use the code button </> so your code looks like this and is easy to copy to a text editor. See How to use the Forum
Your code is too long for me to study quickly without copying to a text editor.
...R
Ok sorry,
I few modified my code, I try to erase information doesn't important.
I would like to write myself in the serial scope the number of stepNumber, because now I need to open the code and changed the number.
I don't arrive to use a other "Serial.read" like in line 50 when I choose Right or Left.
Do you think it's possible to have something like this "1000,r".
Configuration of my Serial Monitor " No line ending, 9600 baud"
There is surely lot of mistake in my code sorry. :frowning:
thank you for the time you give to answer my questions :slight_smile:
int pinBouton;
int stateButton;
int j=0;    //FOR LEFT
int data = 0;
int stepNumberToLeft = 1000;    //Step number To Left
int incomingByte;
void setup(){
Serial.println("*** Program start ***");
Serial.println(" sketch_mar06d");
Serial.println("*** TAPE on 'r' going to the RIGHT or TAPE on 'l' going to the LEFT ***");
  Serial.flush();
                  {digitalWrite(pin32, HIGH); // RIGHT
                                  delay(2);
                                  delay(2);
                                   j=j+1;
                  Serial.println("LOOP 1 RIGHT");}
                                    delay(2);
                                    delay(2);
                                    i=i+1;
                 Serial.println("LOOP 0 LEFT");
void stopmotor(){
  i=stepNumberToLeft;
                           endswitch=true;
                           delay(2);
                           delay(2);
                           e=e+1;
                           //Serial.println("LOOP 5");         //BOUCLE 5
 //Serial.println("LOOP 8");  //BOUCLE 8
Before you try to extend the code, fix them.
There are useless { and } in setup(). Get rid of them.
Put EVERY { on a line BY ITSELF.
Use Tools + Auto Format to fix the piss-poor indenting.
Do NOT use one letter global variable names.
void stopmotor(){
  i=stepNumberToLeft;
      delay(20);    //
You can NOT use delay() in an interrupt service routine.
That ISR needs a complete rewrite. It should stop the motor IMMEDIATELY.
How many times do you need to be told yes? Are you that insecure?
Why?
/*  Step_Motor_
int pinBouton;
int stateButton;
int e = 0;    //RETURN TO RIGHT AFTER HIT BUTTON
int i = 0;  //FOR RIGHT
int j = 0;  //FOR LEFT
int data = 0;
bool endswitch = false;
int incomingByte;
  attachInterrupt(digitalPinToInterrupt(3), stopmotor, FALLING);
  Serial.flush();
  while (Serial.available() > 0) //Serial.available will tell the board to look at the information being sent to it through the serial port.
    { if (incomingByte == 'r')
      { digitalWrite(pin32, HIGH); // RIGHT
        while (j < stepNumberToRight) {
          digitalWrite(pin31, HIGH);   //pin31 +5V FRONT MONTANT
          digitalWrite(pin36, LOW); //pin36 0V
          delay(2);
          digitalWrite(pin36, HIGH); //pin36 +5V
          delay(2);
          j = j + 1;
    //digitalWrite(pin31, HIGH);
    //digitalWrite(pin31, LOW);
    { if (incomingByte == 'l')
        while (i < stepNumberToLeft) {
          delay(2);
          delay(2);
          i = i + 1;
        digitalWrite(pin31, LOW); //pin31 0V START_RESET
void stopmotor()
  endswitch = true;
  digitalWrite(pin32, HIGH);  //RIGHT
  while (e < 500) { /// temps de retour de charriot vers la droite
    delay(2);
    delay(2);
    e = e + 1;
Now my code look like this.
I read your link above but I try and I don't arrive to chose my stepNumber.
valleevi:
Make the code for receiving serial data separate from the code for controlling the motor. Then you can test both parts separately.
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
Your code in loop() might look like this
   recvWithEndMarker();
   parseData();
   moveMotor();
The code in the moveMotor() function would get its data from a variable that is updated from the Serial data.
...R
ok, some things like that? It is better to compartmentalize?
but now I can not write an information, when I write 'r' for example nothing happens I do not even see that I go through my loop "void moveMotor" because I do not see "void moveMotor RIGHT "on my screen.
/*  Step_Motor_
int pinBouton;
int stateButton;
int j = 0;  //
int data = 0;
int number;  // Step number
int incomingByte;
boolean newData = false;
const byte numChars = 32;
char receivedChars[numChars];   //an array to store the received data
char tempChars[numChars];   //temporary array for use when parsing
//variables to hold the parsed data
char messageFromPC[numChars] = {0};     //Direction in which the motor will go
int integerFromPC = 0;                  //Number of step the motor will do
  Serial.println(" sketch_mar07d");
  Serial.println("***Start end finish your order with '<' and'>' ***");
  recvWithStartEndMarkers();
  if (newData == true) {
    strcpy(tempChars, receivedChars);
    // this temporary copy is necessary to protect the original data
    //   because strtok() used in parseData() replaces the commas with \0
    parseData();
    stepNumber();
    moveMotor();
    newData = false;
void recvWithStartEndMarkers() {
  static boolean recvInProgress = false;
  static byte ndx = 0;
  char startMarker = '<';
  char endMarker = '>';
  char rc;
  while (Serial.available() > 0 && newData == false) {
    rc = Serial.read();
    if (recvInProgress == true) {
      if (rc != endMarker) {
        receivedChars[ndx] = rc;
        ndx++;
        if (ndx >= numChars) {
          ndx = numChars - 1;
      else {
        receivedChars[ndx] = '\0'; // terminate the string
        ndx = 0;
        newData = true;
    else if (rc == startMarker) {
      recvInProgress = true;
void parseData() {      // split the data into its parts
  char * strtokIndx; // this is used by strtok() as an index
  strtokIndx = strtok(tempChars, ",");     // get the first part - the string
  strcpy(messageFromPC, strtokIndx); // copy it to messageFromPC
  strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
  integerFromPC = atoi(strtokIndx);     // convert this part to an integer
void showParsedData() {
  Serial.print("Message ");
  Serial.println(messageFromPC);
  Serial.print("Integer ");
  Serial.println(integerFromPC);
void moveMotor()
  if (messageFromPC == 'r')
    Serial.println("void moveMotor RIGHT");
  if (messageFromPC == 'l')
    Serial.println("void moveMotor LEFT");
void stepNumber()
  while (j < number) {
    delay(2);
    delay(2);
    j = j + 1;
    Serial.println("void stepNumber");
void stopmotor()
  endswitch = true;
    delay(2);
    delay(2);
    e = e + 1;
I assume you don't have compiler warnings set to 'all' in preferences. I do and if I compile your code I get this:
/Users/martin/Documents/Arduino/test/test.ino: In function 'void moveMotor()':
/Users/martin/Documents/Arduino/test/test.ino:123:24: warning: ISO C++ forbids comparison between pointer and integer [-fpermissive]
You could try:
if (messageFromPC[0] == 'r')
Sorry, no I don't have this parameter. And what is different when you have compiler to 'all' ?
with this modification, now I see I go in void moveMotor thanks to my Serial.println"void moveMotor RIGHT".
this would like to say, when I write '<r,1000>' my program went to this loop.
But nothing happed, my loop for number of step doen't functionning for the moment.
Thank you very much :slight_smile:
It's functioning.
Now I doesn't understand why but, I already need to do <r,0> and after <l,1000> for example.
If I try to say in first going to Left my step motor go to right :/.
I know, I need to send information in pin 31, it's "Start/Reset" function, it's a rising front.
My code look like this now :
/*  Step_Motor_
int pinBouton;
int stateButton;
int j = 0;  //
void setup(){
  Serial.println(" sketch_mar07g");
  Serial.println("***Start end finish your order with '<' and '>' ***");
void loop(){
    parseData();
    stepNumber();
    moveMotor();
    newData = false;
  char rc;
    rc = Serial.read();
        ndx++;
          ndx = numChars - 1;
      else {
        ndx = 0;
        newData = true;
  Serial.print(" Direction ");
  Serial.print(" Numbers of step ");
void moveMotor(){
    //Serial.println("void moveMotor RIGHT");
  if (messageFromPC[0] == 'l')
    //Serial.println("voimoveMotor LEFT");
void stepNumber(){
  while (j < integerFromPC) {
    delay(2);
    delay(2);
    j = j + 1;
    //Serial.println("void stepNumber");
void stopmotor(){
  endswitch = true;
    delay(2);
    delay(2);
    e = e + 1;
Hello, I don't understand why when my program want in attachInterrupt doesn't stop,
for example when I say <l,5000> and my carriage hit the button at 2000, the step motor did 500 step to the right but after it finished the last 3000 step, and I hit my structure. :confused:
/*  Step_Motor_
int pinBouton;
int stateButton;
int j = 0;  //
  Serial.println("***Enter your order like this ' < 'r' or 'l' ',' 'number of step you want' ****");
  Serial.println("Example : <r,1000> ");
    parseData();
    stepNumber();
    moveMotor();
    showParsedData();
    newData = false;
  char rc;
    rc = Serial.read();
        ndx++;
          ndx = numChars - 1;
      else {
        ndx = 0;
        newData = true;
  Serial.print(" Direction : 'r' for Right and 'l' for Left : ");
  Serial.print(" Numbers of step is : ");
void moveMotor() {
  { digitalWrite(pin32, LOW); // LEFT
void stepNumber() {
    delay(2);
    delay(2);
    j = j + 1;
void stopmotor() {
  endswitch = true;
    delay(2);
    delay(2);
    e = e + 1;
You've got delay AND serial prints in an interrupt service routine.
Don't do either.
You think there is an other solution to do the same action ?
I just want if my carriage hit the button during the step motor going on left , it change immediately of direction "go to right" during 500 step and after stop. It's finish.
pinBouton is never assigned a value.
Pin 3 is never configured.
my pin 3 is in same connection of my ground
