Hi all,
I need to choose a battery to power a small servo that will be worn in an assisted-thumb that I am designing for osteo-arthritis sufferers (like my wife) - ideally it would be a LiPo battery for weight consideration. I am using a Seeeduino Film (http://www.seeedstudio.com/depot/seeeduino-film-p-689.html?cPath=132_133) - an Arduino compatible micro on a thin film. I will be running the Seeeduino from a 110mAh battery but it will be controlling a servo, so I want to power the servo independently and just connect the ground.
The Seeeduino charging and power frame is rated at a max of 280mAh, hence seperate batteries.
The batteries I was considering in series give me 7.4v @ 2000mAh (http://www.coolcomponents.co.uk/catalog/product_info.php?cPath=87&products_id=157)? If so, is it possible to charge them in-circuit or is it best to disconnect them and charge them seperately?
The servo I am considering is Servo Shop. This gives me the right amount of torque, programmability and size.
Regards,
Morrolan
