I have a quest(ion) to find a good 24 - 36 V/ 8 – 15 A motor shield for my project.
At the moment I have 2 DC motors, that I would like to use for an electric assisted bicycle. One is a 250 W (@ 36V) Hub-motor (build inside a bicycle wheel), the other one is a 350 W (@ 24V) sprocket-motor. For convenience sake I’ll start my project with the 36 V Hub-motor.
The power is supplied by semi-traction lead acid /lead gel batteries, placed in series (in the future I would like to upgrade to Li-ion).
I want to use PWM for speed control, in combination with a throttle handle bar (originally for the Hub-motor). I would like to use an Arduino in combination with a good but inexpensive motor shield.
So I think I should be looking for a 36 V, at least 8 A motor shield, compatible with an Arduino.
At last but not least, I would prefer to use an European based website/shop (I’m located in Rotterdam, the Netherlands).
My quest brought me this: www.robotshop.com 1 and www.robotshop.com Some of these robotshop Pololu motor shields talk about an absolute maximum of 40 V, so I wonder if it applies for all.
Questions:
- Are the above motor shields good for my project?
- Are there any motor shields out there, preferably in the 30 – 100 Euro range, matching the requirements?
- The 12 V lead batteries have a peak voltage of about 13.5 V, three in series would equate to a maximum voltage of 40.5 V instead of 36 V. Do I need to consider this higher voltage when looking for a motor shield, or can I use a version advertised as 36 V without risk of damage?
Alternatively I found this on Amazon: All in one solution
- It looks like it could easily be implemented (without using the original throttle handle bar). Are there any risks with this approach, or is it feasible?
If all else fails (I’ve read very mixed reviews): Banggood
Best regards Cubo
