I've changed the transitor, put it on the other side, tested all combinaisons. Done plenty of other tests. But never comes to get it respond like I'm waiting.
Could someone explain me what I'm doing wrong.
Thanks
Missing gate resistor. Probably not good for the transistor.
MOSFETS don't really require gate resistor as the gate is insulated from the source and drain terminals. Sometimes a gate pull down resistor is required in case the signal driving the gate is removed causing a float condition.
Connect the Arduino, D and LED power's ground together.
So as a test I've connected:
arduino pin 13 to "1- GATE"
"2- DRAIN" to arduino pin GND
arduino Power 5v to a led
second led leg to "3- SOURCE"
This shows three pins
Gate goes to digital or pwm out on Arduino. It's a logic level input device no other stuff needed.
+12V to the positive on the LED strip
Source to the - on the LED strip
Drain goes to ground
You should have the Arduino powered either by USB or it's power supply.
The ground of the Arduino must be connected to the ground of the +12V supply. I'd suggest the power supply be better than 6A by 25 percent so 7.5A just to keep it from maxing out.
I've changed this from source to sink, sorry if you got one of the revisions I need to preview better.
You should have a heatsink for that. At max current it may get toasty. You can easily hack one together and use left over heat sink grease.
For precision this can help but it has math Thermal conductance and resistance - Wikipedia
True but a off gate looks like an uncharged capacitor so you might want to add a 100R series resistor to protect the arduino pin from the brief over current that occurs when the FET being switched on.
When using a MOSFET it is important to be clear about which pin is the drain (D), which is the gate (G) (the equivalent pin is labelled 'Input' in the VNP10N06) and which is the source (S). The drain in connected to the load, the gate to the input signal and the source to 0V.
this is my "final testing stage" before realization !
YouTube Video:
This is a test application for controlling RGB strip led with Arduino. It used 2 Arduino: * one for controlling strip led with TLC5941 so I can control "as many strip chunk as I want". * Second for decoding IR messages. (The two Arduino libraries were incompatible on the same chip) Communication between the cards is done by connecting 5 digital output pin from IR card to the 5 analog (but digital mode) of the "master" card. +2 other pins for communication ack. I send binaries data, each code corresponding to one touch from the remote. I'll be using this to do lightning in my stairs ! But this will be another video !
I'll post something on the Arduino Projects Page when completely done !
