Hello everyone, I'm currently working on a project and I'm a little bit stuck. In a nutshell I need my arduino to control a linear motor and a speaker, while being controlled wirelessly through xbee.
I have a 12v linear motor and a current-force curve. From there, for the force I need it to exert I conclude that I need about 1A.
The speaker I have is up to 24W, and it's 90 1w/1m db but I need it only to go to about 100db, so about 16w (give or take I don't care), meaning about 8v@2A.
The battery I'm using is 12v, 5Ah.
I want it to connect something like this;
Battery into;
-LM5296 (5v version) into Arduino
-LM5296 (3.3v version) into xbee
-Tip120 into Linear Motor
-some kind of amp into speaker.
Then Arduino is connected into;
-xbee
-adafruit wave shield
-Tip 120 into linear motor
That's pretty much how I planned this with my very limited know-how. I have a couple of problems however.
First, I have no idea how to power up the speaker. I guess, I would need something like this? But I need 16w, not 3.7, also mono is enough for me.
Then, how can I adjust the volume of the sound produced? On the manuals for adafruit wave shield the mechanical potentiometer does this, but I need to do it wirelessly. And indeed, do I even need the said shield? Can I use something like this and read the file myself? I guess the code would be too much of a bother to write and I better use the shield right? (at least that's my reasoning)
And last, is my logic here sound or did I just write a lot of rubbish?
But mostly I guess I need help picking an amp for my speaker.
Thanks guys, I already learned tons form these boards just reading them, and I hope to contribute too, in time :).
