choosing high amperage adapter
hi everybody I am using 3 dc motors (12 volt) and 3 encoders by 2 drivers and 3 Arduino boards (2 Uno, 1 Due) is it possible to use an adapter (12 volt and for example 10 amps)? and generally what happened if I use and adapter with high amperage but same voltage?
Having more amps available than are needed causes no problem and is, in general, a good idea.
The important thing is to have the correct voltage.
Electric and electronic devices just draw the current they require if the voltage is correct.
...R
Robin2:
...R
thanks
Its important with high current power supplies to ensure all the circuits from it have adequate fuses
or polyfuses to prevent wiring fires. The classic mistake is to use a chunky supply to a big load, and
also run a low-current circuit from the same supply using skinny wire and without suitable protection.
If the low-current circuit happens to fail short circuit all that thin wire erupts into flame.
