Choosing instrumentation amplifier
Hello everone,
I have a sensor (custom designed) pressure and bubble sensor which is having following specifications.
output: 5mv offset to 30mv dc analogue output
sensitivity/gain: 15mv/bar (It will detect negative pressure, usually it can detect up to -0.5 bar)
Bubble sensor:
The output should around
25mv to 1.2V dc
So, i have to amplify this signal to 0-5V which arduino can measure. I have read that have to use opamp with non inverting opamp with 2 stage or gain of 160 which actually difficult or i can use instrumentation amplifier.
I have read most of in amp datasheet and confused much more. I have tried software for simulation it suggests AD8237, AD627 are suitable in my application also software of texas instrument WEBENCH
suggest LMV842, LMV841, LMV844 are suitable.
Can anyone tell me which opamp i have to use which is easier and of coarse low cost in my application . Or any new opamp i can use?
Also providing design of this opamp.
Opamp design
Find a rail-to-rail op-amp that can work om 5V single supply.
If your sensons can be slightly loaded, then a single amp and two resistors is enough to make your amplifier.
Without loading the sensor - add a voltage follower in front.
5..30mV => times 150 => 0.75 ..4.5V
25mV..1.2V => times 4 => 0.1 .. 4.8V
a single chip, similar to MCP6004 (and many others) can do the job.
Please post the datasheet of the sensor, not your attempt to explain whats in the datasheet.
@kunt_ny: I am not getting what is meaning of sensor is slightly loaded or not actually i am doing first time the analog design. Thanks for your suggestion am verifying the datasheet of MCP6004.
@Markt: Actually i dont have datsheet of this sensor i only have information that i have posted.
Sensor load => The current the sensor can source/sink without affecting its reading.
(Sorry for my 10fold error in my earlier calculations corrected..)
Ok i have checked the datasheet you have suggested MCP6004 as it is low power opamp suitable for general pursose application. Actually one thing is not clear to me that where to use normal opamp and where to use instrumentation amplifier? I have read that when want to amplify mV signal to V signal it is better to use in amp than normal opmap.
And as i told you that dont have datasheet of sensor so first i have started my work to select the correct opamp-instrumentation amplifier for it.
Instrument amp are built from 3 opamps (u'll see how in the datasheet for MCP600x).
In this case the inexpensive solutuion will work pretty good..
The one sensor that needs 150x amplification may be solved with HX711 (digital readout)
The other is easily solved with an rail-to-rail opamp. (your circuit must be calibrated anyway)
