Hello. I am trying to start an arduino project wherein a knock pattern on the wall beside my bed (detected by a piezo sensor) triggers a lamp to switch on and off.
I don't think I would like to work with high voltages yet and use relays and that, so I figured a better (safer) solution would be to use a motor (maybe a rotating servo) to physically flip the switch on the lamp.
I'm not sure if a small motor like this would have enough torque (?) to actually flip the switch, since I want to make the system as compact as possible. What alternatives can you suggest?
Tricky - really needs two push actuators for on and off, then you can't get at the switch yourself... A separate
wirelessly controlled switch (hack into the push buttons on the control fob) might be simpler.
I'm actually just going to use a relay, but instead of connecting it directly to the lamp, I'm sorta doing something similar to this (split a one-gang extension lead halfway, connect the relay in between). This will allow me to use the sensor with any appliance I plug into it.
