I'm not sure if this is the correct forum but I have a few questions regarding the selection of resistor pull-ups values. Currently I'm designing a I2C isolation circuit and when dealing with pull-ups I'm unsure what pull-up values to apply to signal buses. Is there a general rule to follow. I've attached a picture of the schematic as well. If you can point me in the right direction it would be greatly appreciated.
Not too much of an expert here..
Pull-up resistor value basically depends on wire capacitance.
There seem to be several I2C standards. One is 400pf/3mA.
The P82B96DRG4 seems to have that standard in the input side.
That means the two 1K input resistors are too low in value (5mA).
4k7 pull-up is widely used if the bus capacitance is low (short wires/tracks).
The output of the IC is another standard. 4000pf/30mA.
Basically, use 4k7 per bus wire if the wires are short and you only have two devices on the bus.
Lower values to 3k3 if the wire is a bit longer ( I use 8meters of Cat6 with 3k3).
Don't go lower than ~1k7 if one of the device on the bus has the 400pf standard.
Leo..
Thank you in advance.
Question? Why are you using 100pf capacitors? I would think 100nf or 1uf would be a better choice. The whole point of a bypass capacitor is to provide highspeed logic switching current. 0.1nf is not very much charge.
