Miniflyer:
Any ideas? Would be great to not have to manually change everything if i change number of LEDs, Strips or something else....
Most of the code can be done with arrays, but the actual FastLED.addLeds statements have to be done individually. If you know the maximum number of LED strips you will be using, you can use compiler directives to selectively include only as many FastLED.addLeds statements as needed. As for using varying numbers of LEDs per strip, setting up a multi-dimensional array for that would be complex, probably involving an array of pointers to the actual LED arrays. If you have sufficient memory, its probably easier to make all LED arrays the length of the longest strip, and have the code handle the actual length, having FastLED send data for 25 pixels to a strip that only has 15 LEDs doesn't do any harm except for the slightly longer time needed.
Here is a modified version of SteveMann's code that will let you set from 1 to 8 strips, the only thing you need to change is the definition of NUM_STRINGS on line 9 and the rest of the code will adjust automatically.
#include <FastLED.h>
#define SKETCH "Curtain8cOTA.ino"
#define DEBUG false //set to true for debug output, false for no debug ouput
#define Serial if(DEBUG)Serial
const byte NUM_LEDS = 25; // Per string
#define NUM_STRINGS 8 //number of LED strings, maximum of 8
const byte DATA_PIN1 = 2; //only necessary to define pins for the number of strings actually used
const byte DATA_PIN2 = 3; //any additional pin definitions will be ignored
const byte DATA_PIN3 = 4;
const byte DATA_PIN4 = 5;
const byte DATA_PIN5 = 6;
const byte DATA_PIN6 = 7;
const byte DATA_PIN7 = 8;
const byte DATA_PIN8 = 9;
const byte BRIGHTNESS = 100;
#define LED_TYPE WS2812B
#define COLOR_ORDER GRB
CRGB leds[NUM_STRINGS][NUM_LEDS]; // This is an array of leds. One item for each led in your strip.
CRGB leds_Saved[NUM_STRINGS]; // Save the LED color here (for the drip function)
// Variable holding the timer value so far. One for each string of LEDs
unsigned long leds_timer[NUM_STRINGS];
// Time periods of drips in milliseconds
unsigned long leds_Interval[NUM_STRINGS];
unsigned long dripSpeedFast = 2U;
unsigned long dripSpeedSlow = 75U;
// Delay between drips (ms)
int intervalMin = 100;
int intervalMax = 500;
#define CurtainColor CRGB(0x001bff) //Blue (r=00, g=1b, b=ff)
#define MGPu CRGB(0x8010ff) // Mardi Gras Purple
#define MGGr CRGB(0x2cb004) // Green
#define MGGo CRGB(0xff4a00) // Gold
// =========================== setup() ===========================
#ifdef SKETCH
Serial.println(F(SKETCH));
#endif
Serial.println(F("---------------"));
// The initial interval between drips in milliseconds
for (byte i = 0; i < NUM_STRINGS; i++) {
leds_Interval[i] = random(intervalMin, intervalMax);
// sanity check delay - allows reprogramming if accidently blowing power w/leds
// This tells the library that there's a strand of LED_TYPE on pin DATA_PIN1 to DATA_PIN3,
// and those leds will use the led array leds_1 to leds_3, and there are NUM_LEDS of them.
FastLED.addLeds<LED_TYPE, DATA_PIN1, COLOR_ORDER>(leds[0], NUM_LEDS).setCorrection(TypicalLEDStrip);
#if (NUM_STRINGS >= 2)
FastLED.addLeds<LED_TYPE, DATA_PIN2, COLOR_ORDER>(leds[1], NUM_LEDS).setCorrection(TypicalLEDStrip);
#endif
#if (NUM_STRINGS >= 3)
FastLED.addLeds<LED_TYPE, DATA_PIN3, COLOR_ORDER>(leds[2], NUM_LEDS).setCorrection(TypicalLEDStrip);
#endif
#if (NUM_STRINGS >= 4)
FastLED.addLeds<LED_TYPE, DATA_PIN4, COLOR_ORDER>(leds[3], NUM_LEDS).setCorrection(TypicalLEDStrip);
#endif
#if (NUM_STRINGS >= 5)
FastLED.addLeds<LED_TYPE, DATA_PIN5, COLOR_ORDER>(leds[4], NUM_LEDS).setCorrection(TypicalLEDStrip);
#endif
#if (NUM_STRINGS >= 6)
FastLED.addLeds<LED_TYPE, DATA_PIN6, COLOR_ORDER>(leds[5], NUM_LEDS).setCorrection(TypicalLEDStrip);
#endif
#if (NUM_STRINGS >= 7)
FastLED.addLeds<LED_TYPE, DATA_PIN7, COLOR_ORDER>(leds[6], NUM_LEDS).setCorrection(TypicalLEDStrip);
#endif
#if (NUM_STRINGS >= 8)
FastLED.addLeds<LED_TYPE, DATA_PIN8, COLOR_ORDER>(leds[7], NUM_LEDS).setCorrection(TypicalLEDStrip);
#endif
FastLED.setBrightness(BRIGHTNESS);
// Start with all LEDs off.
oneColor(CRGB::Black);
// Curtain color- the LEDs normal color
//oneColor(CRGB::Blue);
oneColor(CurtainColor);
leds_timer[i] = millis();
// =================== loop() ===================
byte i = rrandom (1, NUM_STRINGS); // Drip random strings, no duplicates
drip_x(i - 1);
delay(random(intervalMin, intervalMax));
// =========================== oneColor() ===========================
void oneColor(CRGB myColor) {
// Light the leds one at a time. Leave them on.
for (int ledNum = 0; ledNum < NUM_LEDS; ledNum = ledNum + 1) {
leds[i][ledNum] = myColor;
FastLED.show();
delay(10); // Not needed, but you can see the leds light up sequentially.
// =========================== drip_x() ===========================
// Drip a white LED along the string.
void drip_x(byte drip_strip) {
// For each LED
// save the current color, set the LED to white, delay, then restore the color.
Serial.print(F("drip_"));
Serial.print(drip_strip);
Serial.println(F("..."));
//for (i = 0; i <= NUM_LEDS; i++) {
for (int8_t i = NUM_LEDS - 1; i >= 0; i--) { // Reverse the direction of the drip
Serial.println(i);
leds_Saved[drip_strip] = leds[drip_strip][i];
leds[drip_strip][i] = CRGB::White;
FastLED.show();
delay(random(dripSpeedFast, dripSpeedSlow)); // Speed of the drip. Lower is faster
leds[drip_strip][i] = leds_Saved[drip_strip];
FastLED.show();
leds_timer[drip_strip] = millis(); // remember when we dripped
leds_Interval[drip_strip] = random(intervalMin, intervalMax);
// =========================== rrandom() ===========================
// Generate a random number with no duplicates.
int rrandom(int low, int high) {
// Generate a random number between 'low' and 'high'
static int previous_i = 0;
static int i = random(low - 1, high + 1);
while (i == previous_i || i == low - 1 || i == high + 1) {
previous_i = i;
return i;
