Christmas lights to music
Hi everyone!
I hope this is the right place for this, if not, I will move it.
I have done all of the wiring for this project and I have run into an issue.
I am using the Arduino Uno.
All of the 3 digital outputs(6,7,8) are working for the channels.
However, the 5 analog outputs(A1-A5) do not work for the channels, so only 3 out of the 8 work.
I have looked through the code and have not found any issues.
I will attach it here.
Any suggestions or ideas?
Thanks in advance!
Kat
Christmas_Lights_2010.ino (5.31 KB)
What happens when you write a simple little test program that writes to the analog pins?
int channels[]={6,7,8,15,16,17,18,19};
I don't see where your code writes to the analog pinsl...
It looks like you should be connected to pins 15-19 instead of the analog pins. Are you using an Arduino Mega? (My Uno doesn't have those pins.) Or, is that a "trick" that I'm not aware of?
DVDdoug:
Yes, you can refer to analog pins A0 to A6 as pins 14 to 19.
Try this change:
  volume = volume / 12;
I never saw these messages.
I apologize!
I will try the volume / 12 change right away.
Thanks, PaulRB!
-Kat
Or do you mean 5 analog inputs?
Tom.... :slight_smile:
Yes, that. Whoops.
:confused:
The analog channels(15-19) will work if the volume is set to volume / 12, but then the digital channels(6-8) do not.
I will try to figure out a solution for this.
Thanks all!
Its not well written. Getting all the leds to work means having to play around with the "/ 30" and the "i +3" in doVuMeter() until you get it just right. It would be better if the sketch automatically adjusted to the levels on A0 and scaled those to use all 8 leds.
 * This example plays every .WAV file it finds on the SD card in a loop
#include "WaveHC.h"
#include "WaveUtil.h"
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the volumes root directory
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
uint8_t dirLevel; // indent level for file/dir names    (for prettyprinting)
dir_t dirBuf;     // buffer for directory reads
int channelsLength = 8;
long volume;
long v2;
 * Define macro to put error messages in flash memory
#define error(msg) error_P(PSTR(msg))
// Function definitions (we define them here, but the code is below)
void play(FatReader &dir);
//////////////////////////////////// SETUP
  for (int i = 0; i < channelsLength; i++)
  pinMode(channels[i], OUTPUT);
  Serial.begin(9600);           // set up Serial library at 9600 bps for debugging
  putstring_nl("\nWave test!");  // say we woke up!
  putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
  Serial.println(FreeRam());
  //  if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    error("Card init. failed!");  // Something went wrong, lets print out why
  // enable optimize read - some cards may timeout. Disable if you're having problems
  card.partialBlockRead(true);
  // Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {   // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                           // we found one, lets bail
  if (part == 5) {                     // if we ended up not finding one  :(
    error("No valid FAT partition!");  // Something went wrong, lets print out why
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(),DEC);     // FAT16 or FAT32?
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    error("Can't open root dir!");      // Something went wrong,
  // Whew! We got past the tough parts.
  putstring_nl("Files found (* = fragmented):");
  // Print out all of the files in all the directories.
  root.ls(LS_R | LS_FLAG_FRAGMENTED);
//////////////////////////////////// LOOP
  root.rewind();
  play(root);
  doVuMeter();
void doVuMeter(){
  Serial.print("VuMeter");
  volume = 0;
  for (int i=0; i < channelsLength; i++) {
    v2 = analogRead(0) - 350;
    if (v2 < 0)
      v2 *= -1;
    if (v2 > volume)
      volume = v2;
    delay(5);
  volume = volume / 30;
  //putstring("\n");Serial.print(volume);
  for (int i = 0; i < channelsLength; i++) {
    if (volume > i +3 ){
      digitalWrite(channels[i], HIGH);
    else{
      digitalWrite(channels[i], LOW);
/////////////////////////////////// HELPERS
 * print error message and halt
void error_P(const char *str)
  PgmPrint("Error: ");
  SerialPrint_P(str);
  sdErrorCheck();
  while(1);
 * print error message and halt if SD I/O error, great for debugging!
void sdErrorCheck(void)
  if (!card.errorCode()) return;
  PgmPrint("\r\nSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  PgmPrint(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
 * play recursively - possible stack overflow if subdirectories too nested
  FatReader file;
  while (dir.readDir(dirBuf) > 0) {    // Read every file in the directory one at a time
    // Skip it if not a subdirectory and not a .WAV file
    if (!DIR_IS_SUBDIR(dirBuf)
         && strncmp_P((char *)&dirBuf.name[8], PSTR("WAV"), 3)) {
      continue;
    Serial.println();            // clear out a new line
    for (uint8_t i = 0; i < dirLevel; i++) {
       Serial.print(' ');       // this is for prettyprinting, put spaces in front
    if (!file.open(vol, dirBuf)) {        // open the file in the directory
      error("file.open failed");          // something went wrong
    if (file.isDir()) {                   // check if we opened a new directory
      putstring("Subdir: ");
      printEntryName(dirBuf);
      dirLevel += 2;                      // add more spaces
      // play files in subdirectory
      play(file);                         // recursive!
      dirLevel -= 2;
    else {
      // Aha! we found a file that isnt a directory
      putstring("Playing ");
      printEntryName(dirBuf);              // print it out
      if (!wave.create(file)) {            // Figure out, is it a WAV proper?
        putstring(" Not a valid WAV");     // ok skip it
        Serial.println();                  // Hooray it IS a WAV proper!
        wave.play();                       // make some noise!
        uint8_t n = 0;
        while (wave.isplaying) {// playing occurs in interrupts, so we print dots in realtime
          doVuMeter();
//          delay(100);
        sdErrorCheck();                    // everything OK?
        // if (wave.errors)Serial.println(wave.errors);     // wave decoding errors
