When my code below is included as part of a larger program it returns State : 400 ie an error and there is no update in Thingspeak.
The remaining features of the program are all OK ie an
attachInterrupt(pin_irq, IRQcounter, FALLING); //This is a small minimal code routine.
LCD display, WiFi Console, Serial Monitor all OK
When the same basic Ciao.write code is run by itself it returns State : 200 ie data is correctly sent and received by Thingspeak.
However when I include this function in the main program I get State : 400
I have tried using cli(); sei(); but this crashes the main program.
Using library Wire at version 1.0 in folder: /Users/mack/Library/Arduino15/packages/arduino/hardware/avr/1.6.19/libraries/Wire
Using library EEPROM at version 2.0 in folder: /Users/mack/Library/Arduino15/packages/arduino/hardware/avr/1.6.19/libraries/EEPROM
Using library Arduino_Uno_WiFi_Dev_Ed_Library at version 0.0.3 in folder: /Users/mack/Documents/Arduino/libraries/Arduino_Uno_WiFi_Dev_Ed_Library
Using library LiquidCrystal at version 1.0.6 in folder: /Users/mack/Documents/Arduino/libraries/LiquidCrystal
Sketch uses 19564 bytes (60%) of program storage space. Maximum is 32256 bytes.
Global variables use 1596 bytes (77%) of dynamic memory, leaving 452 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur.
Any suggestions please.
void uploadtothingspeak(){
String uri = "/update?api_key=";
uri += APIKEY_THINGSPEAK;
uri += "&field1=";
uri += String(savepulse_count1_kWh);
Serial.println(uri);
Ciao.println("Send data on ThingSpeak Channel");
CiaoData data = Ciao.write(CONNECTOR, SERVER_ADDR, uri);
if (!data.isEmpty()){
Ciao.println( "State: " + String (data.get(1)) );
Ciao.println( "Response: " + String (data.get(2)) );
else{
Ciao.println("Write Error");
