Circuit Correct? Help me!
Hello,
I’m doing a project with Arduino and I have problems, I hope you can help me.
My idea is to create a system to the management of my turtle water tank. I begin creating a simple part of the project with a sensor to alert me when the water level is low. If this happens I activate the motor to put water inside the tank again.
I know that I can do this without arduino but I will put more logic in the future.
I create a circuit but something is wrong. (image attached)
I use this components:
I don’t know why but the motor is very slow and the mosfet is very hot. I measure and the battery has 8,30V but in the motor I have 1,80V. The current is aprox 1,2A.
I don’t have sink in the mosfet but I think that this is not my main problem.
I’m new in electronic and I can’t understand what is happening.
Can you help me?
Thanks :smiley:
Your circuit seems okay, but the mosfet should not get hot. Perhaps the source and drain are exchanged. Can you use a 'logic level' n-channel mosfet ? With that you don't need the extra transistor so the circuit is simpler and less chance for error. The motor/pump with diode connected to the + side of the battery. I hope you don't use PWM for the mosfet, only a simple on and off.
The sensor and motor are very cheap. You have to test them how long they will last. Perhaps a day, perhaps a few years. Can you measure the current for the motor without the mosfet ? So you know the current that motor requires.
Check this datasheet: http://www.irf.com/product-info/datasheets/data/irf4905.pdf
You have Drain and Source exchanged.
Drain is pin 2 and Source is pin 3.
IRF4905 is 20mOhm mosfet, so at 1.2A there should be 24mV voltage drop and 29mW of heat.
Either is misconnected or damaged or both.
Disconnect motor and troubleshoot with friendlier load that would not damage IRF even if misconnected, e.g. 12V/2W bulb. Make sure BC547 is switching. Then make sure IRF4905 is switching. When this is all working, connect motor.
luisilva, when drain and source are swapped, should not this MOSFET function as schottky? Why high voltage drop then ?
Hello,
Thanks for your answers.
In the datasheet I don't see how to connect, I search it on internet but I don't remember where.
I have connnected the mosfet this way:
  • Left Pin: To transistor BC547 (So I think is Gate)
  • Center Pin: To Motor and Diode
  • Right Pin: To 9V Battery
Is this right?
If the connections are like you are saying they are OK.
Left is pin number 1 and is the gate; Centre is pin number 2 and is Drain; Right is pin number 3 and is Source.
If is a P-channel MOSFET you must connect Source to +9V.
And the diode is correct? Now I am thinking test I was doubt when I connected it.
I put the line side in positive motor and the other in negativa motor.
Thanks
You don’t need the diode. The diode is inside the MOSFET.
luisilva: You don't need the diode. The diode is inside the MOSFET.
You need a fly-back diode over an inductive load. Always. In some cases a filter is used, but I would still recommend the fly-back diode. If you want to do it right, you need a fast diode like the UF4007. An 1N4007 is only for 50/60Hz mains rectifier and could be too slow for a fast mosfet.
When talking about DC of course.
Peter_n:
If you have a H-bridge of this kind of MOSFET, where did you put that diode?
Can you explain to me what means the picture attached?
I put the diode because I previously burn out an H-Bridge and I have fear :)
But my question is: The diode has correct orientation? Maybe, If the diode is reverse maybe it can do the motor get low voltage.
The part with the line is conected to center pin of mosfet and positive of the motor.
And if the diode is ok, must I remove it?
Thanks
marioqn: I put the diode because I previously burn out an H-Bridge and I have fear :)
Per your diagram the orientation and placement is correct and yes it is required. The mark on the diode will be on the side of the positive connection on the motor.
Then, If the Mosfet and the diode is ok, I don't know where is the problem :(
that is the worst data sheet. I could not find what pins to connect.
I was kinda expecting the pin numbers to be from the bottom looking up and the OP connected from the top looking down.....
this was MUCH more informative
of course, this will actually help the rest of us.
http://catalog.gaw.ru/index.php?page=component_detail&id=7451
Hello Again.
I made some test.
In Mosfet:
Assuming that mosfet is G D S when I put the motor without load (no water flow) I have in DS and GD -4V but when I put water to flow I have -2 V aprox in both.
The same voltage is across the diode.
In BC547:
I think the problem is here because Arduino provide 5V aprox and the center pin (V divisor) has 0,65V so, I think mosfet is not working because of this.
  • The left pin have 9V battery entry with a 4,7K ohm resistance (aprox 8,2V in pin). This pin is connected with left mosfet pin.
  • The center pin have 5V arduino input with a voltage divider with 10k and 1M ohm resistances. In the pin I have 0,65V.
  • The right pin is set to Ground.
The center pin must output 4,95V with the V-Divider formula.
dave-in-nj: this was MUCH more informative
Thanks dave-in-nj and sorry, My english is bad and the picture is too much for me :S
does this help ?
marioqn: I have connnected the mosfet this way:
Is this right?
dave-in-nj: does this help ?
So, I have center and right pin of Mosfet bad? My center Pin goes to Motor and Right to 9V Battery.
The BC547 is ok
luisilva:
So.... Must I put an sink to the mosfet to avoid the heat? Because I can't find the problem
