Circuit Diagram to make 16x56 led matrix using shift registers
hello guys,
i use arduino uno for small projects like 444 led cube, digital post box etc.
Now i got an assignment to create a name board using 88 led matrix.
For that i collected 14 matrix segments and shift registers to make 16
56 led matrix right now im confused about the circuit diagram to connect the columns of two rows. please help me .
Thanks in advance
Does the assignment say that you should use shift registers? If not, it would be better to use max7219 chips, one per matrix.
PaulRB:
max 7219 chips are damn costlier in my city. i can but 10 shift register in the price of one max 7219 chip
thats why i chose to go on with shift registers
You are going to need 16 shift registers, 120+ resistors, 16 transistors (or two uln2803 chips), plus much more space for the wiring and chips. Plus about 10 times more time and effort. And still the results will not be as good as the max chips. Do some calculations to see if you can justify the price of the max chips compared to the extra materials and labour hours required for the shift register solution. This will get you extra marks for your assignment because it is an important business consideration.
Can you buy these from China? Or would that loose assignment marks?
