Circuit from 5V to ground turns Arduino off
Hi
I've just got a Arduino Duemilanove, and I'm quite new to electronics. I followed the push button example and when I push the button the arduino switches off.
I then removed the button and just put a wire straight across and the same thing happens.
So... when i go from the 5V to a resistor straight to the ground it switches off.
Is there a way to fix this?
Is it the right resistor?
Check your wiring - you've got a short-circuit.
Forgot to mention this worked the first time i tried it.
I've tried two different resistors both of which worked the first time.
How can i find the source of the short circuit. All i have is the arduino and the breadboard. I take the 5v and the ground to the board, i then put the resistor in, close the connection and it switches off.
If i use an led, instead of a wire to close the connection it stays on and the led lights up.
I had the resistor in the same line which seemed to short circuit it. Guess i need to do some learning.
What resistor is it? It sounds too smal if you can use it to light up a led.
Update
Ok, this does seem to be an issue with the resistance. I’ll try find a bigger one and see what happens.
Go for 10k
Thanks guys... it was the short circuit, not the resistance.
