CIRCUITO et la librairie Joystique
Bonjour
je veux utiliser le code provenant de CIRCUITO.IO mais en premier j'ai l’erreur "'Joystick' does not name a type" , j'ai fait la correction suivante le "" en plus
"Joystick**
** joystick(JOYSTICK_PIN_VRX,JOYSTICK_PIN_VRY,JOYSTICK_PIN_SW); "
Après j'ai eu l'erreur ''class Joystick_' has no member named 'getX'
" , je ne trouve pas la solution Pouvez vous m'aider?
// Include Libraries
#include "Arduino.h"
#include "Joystick.h"
// Pin Definitions
#define JOYSTICK_PIN_VRX	A1
#define JOYSTICK_PIN_VRY	A0
#define JOYSTICK_PIN_SW	2
// Global variables and defines
// object initialization
Joystick joystick(JOYSTICK_PIN_VRX,JOYSTICK_PIN_VRY,JOYSTICK_PIN_SW);
// define vars for testing menu
const int timeout = 10000;       //define timeout of 10 sec
char menuOption = 0;
long time0;
// Setup the essentials for your circuit to work. It runs first every time your circuit is powered with electricity.
    // Setup Serial which is useful for debugging
    // Use the Serial Monitor to view printed messages
    while (!Serial) ; // wait for serial port to connect. Needed for native USB
    Serial.println("start");
    menuOption = menu();
// Main logic of your circuit. It defines the interaction between the components you selected. After setup, it runs over and over again, in an eternal loop.
    if(menuOption == '1') {
    // PS2 X Y Axis Joystick Module - Test Code
    // Read Joystick X,Y axis and press
    int joystickX =  joystick.getX();
    int joystickY =  joystick.getY();
    int joystickSW =  joystick.getSW();
    Serial.print(F("X: ")); Serial.print(joystickX);
    Serial.print(F("\tY: ")); Serial.print(joystickY);
    Serial.print(F("\tSW: ")); Serial.println(joystickSW);
    if (millis() - time0 > timeout)
// Menu function for selecting the components to be tested
// Follow serial monitor for instrcutions
char menu()
    Serial.println(F("\nWhich component would you like to test?"));
    Serial.println(F("(1) PS2 X Y Axis Joystick Module"));
    Serial.println(F("(menu) send anything else or press on board reset button\n"));
    while (!Serial.available());
    // Read data from serial monitor if received
    while (Serial.available())
        char c = Serial.read();
        if (isAlphaNumeric(c))
            if(c == '1')
    			Serial.println(F("Now Testing PS2 X Y Axis Joystick Module"));
                Serial.println(F("illegal input!"));
                return 0;
            time0 = millis();
            return c;
Je remonte le sujet car j'ai vraiment besoin d'aide!
un lien vers la librairie joystick utilisée ?
Tu as bien chargé tous les fichiers depuis circuit.io en utilisant download firmware dans l'onglet code?
Tu as tout extrait dans ton répertoire sketchbook?
@al1fch La librairie Joystick fait partie des fichiers chargés
Si tu suis la procédure décrite ci-dessus l'application compile sans erreur.
merci fdufnews çà fonctionne
je vais pouvoir avancer sur le panneau de contrôle pour FarmingSimulateur du gamin
Dèjà bon réveillon et bonne année 2019
De rien joyeuses fêtes
