Circular Shifting of Array Contents
Good afternoon,
If someone could help me it would be lovely. I need to make an iterative circular shifting of the contents of an array.
Let’s suppose my array is:
int array = {0, 1, 2, 3, 4, 5}
On the first iteration I want to get
{5, 0, 1, 2, 3, 4 }
on the second
{4, 5, 0, 1, 2, 3 }
on the third
{3, 4, 5, 0, 1, 2 }
and so on…
Thank you in advance,
André
Off-hand I can think of two ways. Either shift the contents (probably wasteful), or use a modulo operator on the array index.
const int elements = 6;
int array[] = {0, 1, 2, 3, 4, 5}
int iteration = 1;
  item1 = array[ elements - ((0 + iteration) % elements) ];
  item2 = array[ elements - ((1 + iteration) % elements) ];
  item3 = array[ elements - ((2 + iteration) % elements) ];
  etc..
  iteration++;
(Could use a for-loop for array access ofc).
At least, I think that should work.
Try this (not tested) although there may be other better solutions…
int myarray[] = {0, 1, 2, 3, 4, 5};
int number = 0;
void displayArray () {
  for (int i = 0; i < number; i++) {
    Serial.print(myarray[i]);
    Serial.print (" ");
  Serial.println (" ");
  number = sizeof(myarray) / sizeof(int);
  displayArray ();
  int tempo = myarray[number - 1];
  for (int i = number - 1; i > 0; i--) myarray[i] = myarray[i - 1];
  myarray[0] = tempo;
  displayArray ();
  delay(2000);
Thank you Raron and Lesept!!
Lesept, your code flows like a charm!!!
Cheers,
André
A more efficient way is to keep track of a start and an end index of your array. For every shift, increase both by 1, roll over if need to, and ... done.
