#define SCREEN_WIDTH 128 // OLED display width, in pixels
int _circularBuffer[SCREEN_WIDTH]; //fast way to store values
int _curWriteIndex = 0; // tracks where we are in the circular buffer
In Setup I have:
for (int i = 0; i < SCREEN_WIDTH; i++) {
_circularBuffer[i] = 24; //Start with graph at midpoint.
And in the Loop I have:
_circularBuffer[_curWriteIndex++] = Distance;
And it is in that last line where I get the error:
'_circularBuffer' does not name a type.
This code has been working for weeks but when I went into it to clean it up some, I started getting this and I don't know what to do about it. My edits had nothing to do with the code I have shown here...unless they did.
Any suggestions would be appreciated.
edit: "Distance" was declared at the start of my code:
Post the code. Or a minimum sketch that has the same problem.
This is fine, so.
# define SCREEN_WIDTH 128 // OLED display width, in pixels
int Distance;
And this topic is a textbook example of why you post the whole sketch!
int Distance;
arduino-cli compile -b arduino:avr:uno --warnings all --output-dir /home/me/tmp --no-color (in directory: /home/me/Documents/sketchbook/Uno_R3/test)
/home/me/Documents/sketchbook/Uno_R3/test/test.ino:16:3: error: '_circularBuffer' does not name a type
Used platform Version Path
arduino:avr 1.8.3 /home/me/.arduino15/packages/arduino/hardware/avr/1.8.3
Error during build: exit status 1
Compilation failed.
No. I'm sorry but I don't. That's why I'm here, to ask someone with more experience than I have to offer some suggestions as to why this error may be present. If you don't have enough info to make an educated guess, then that is the answer.
And do you really want me to post all 349 lines of my code?
Yes. If you still have the error, there is no other way.
349 lines is nothing.
@van_der_decken made the error happen with a tiny sketch. I made it go away with a tiny sketch. This appears to be without your skill level at this time. You are here for help - this is probably a simple matter and as you see, nothing whatsoever to do with anything you've posted.
If you read much on these fora, you will see ppl regularly posting huge amounts of code, and we ask them to try to bake it down.
349 lines is baked enough.
If it helps, it took me some time to see the error… I don't seem to see errors I would never make.
I do now! I finally found it after using Auto Format and seeing that damn curly bracket standing there all by itself.
What I had done was to comment out an IF statement that I was using to conditionally print some variables and failed to grab the ending bracket for the IF.
Why can't the compiler catch that, rather than laying blame on an untyped thing?
It is certainly true that compiler error reporting can get you pointed off the main track.
I dread seeing the red ink after some editing, especially when it says something like your error message reported.
A stray or missing this or that can cause a world of hurt, and a crap ton of essentially useless clues from the compiler.
We may see better error reporting if AI could be harnessed. Don't hold your breath.
In the meantime, make progress through the smallest of steps you can. Good planning and habits help.
Many of my sketches begin as a structural outline of functions that don't do anything other than maybe printing a message about what they will do, one day.
Mostly I work on a section of code I can see - if an error starts happening, the cause , it has to be in front of me.
And of course using a standard format and/or the Autoformat tool will make some errors pop what might otherwise have eluded you.
And here I will say if you haven't done, go to the IDE preferences and crank up all warnings and verbosity. Then read and need the red ink for "warnings" about things that are perfectly legal but may also be perfectly not at all what you meant.
Dunno if it would have helped in this case, and I doubt we'll ever be free of needing to crawl hands and knees like through the code looking for WTF is going on.
