CircularBuffer of CircularBufers
For my project i need to create a CircularBuffer of CircularBuffers. So far i have:
#include <CircularBuffer.h>
namespace data {
typedef struct {
unsigned long position;
unsigned long angle;
unsigned int count;
unsigned int distance;
} record;
CircularBuffer<data::record, 13> sprayposition;
CircularBuffer<sprayposition::record, 8>;
but i can’t get it to work. Any thoughts?
Thanks in advance
No idea if this will work, but it does compile:
struct record {
  unsigned int count;
CircularBuffer<CircularBuffer<record, 13>, 8> bigBuffer;
void setup() {}
void loop() {}
Would love to try this but how do i add data to the structure? For example how would i push 1 to bigbuffer[1]position[1]=1
Building on the example from the library, it seems to work if you use nested loops. Added a couple typedef’s to make it more manageable.
#include <Arduino.h>
namespace data {
typedef struct {
  unsigned long time;
  unsigned int value; bool flag;
} record;
void print(record r) {
  Serial.print(r.time);
  Serial.print("  ");
  Serial.print(r.value);
  Serial.print("  ");
  Serial.print(r.flag);
typedef CircularBuffer<data::record, 10> RecordBuffer;
typedef CircularBuffer<RecordBuffer, 4> BufferBuffer;
BufferBuffer bigBuffer;
RecordBuffer sampleBuffer;
#define SAMPLE_PIN A0
  delay(2000);
  pinMode(SAMPLE_PIN, INPUT);
  Serial.println("STARTING UP");
  unsigned int sample = analogRead(SAMPLE_PIN);
  if (sample != sampleBuffer.last().value) {
    if (sampleBuffer.isFull()) {
      bigBuffer.push(sampleBuffer);
      sampleBuffer.clear();
    sampleBuffer.push(data::record { millis(), sample, sample > 128 });
  if (bigBuffer.isFull()) {
    Serial.println("Stack is full:");
    while (!bigBuffer.isEmpty()) {
      sampleBuffer = bigBuffer.shift();
      while (!sampleBuffer.isEmpty()) {
        data::print(sampleBuffer.shift());
    delay(5000);
    Serial.println("START AGAIN");
