Hi Everyone,
I am working on building a vehicle gauge cluster, and one of the measurement parameters I wanted to include was altitude. I purchased CJMCU-06 pressure and temp sensor (which packages the SPL06-001), naively thinking it would would have a readily available Arduino library. Well, I was almost right.
As it appears, there is no library specifically for CJMCU-06 / SPL06-001, but there is a library for SPL06-007. The library appears to work to the extent that I can get coefficient and temperature readings from the sensor.
What I cannot get is reasonable pressure and altitude values, with the sensor/library returning negative values
Serial.print("praw: ");
Serial.println(get_praw());
Serial.print("praw_sc: ");
Serial.println(get_praw_sc(),3);
Serial.print("pcomp: ");
Serial.println(get_pcomp(),2);
Serial.print("Measured Air Pressure: ");
Serial.print(get_pressure(),2);
Serial.println(" mb");
praw: -4571852
praw_sc: -0.581
pcomp: -507417.53
Measured Air Pressure: -5074.18 mb
I am guessing that the registers the library is reading are not quite the same between SPL06-001 and SPL06-007, and that's why I am getting wonky data.
Does anyone have any experience with this before I go digging through the library, or just chuck this board and buy something with better support?
