Hello everybody,
I have CJMCU-1293 (https://www.aliexpress.com/item/32978180756.html). I would like to connect it to my LOLIN32. The 3.3V should work but I do not know how to connect it because some of the CJMCU-1293 pins has "weird" SPI label.
The CJMCU-1293 pins:
- +5V
- GND
- SCLK
- SDI
- SDO
- CSB
- WCT
- ALAB
- DRDB
The LOLIN32 SPI pins:
- GPIO19 - MISO
- GPIO23 - MOSI
- GPIO18 - SCK
- GPIO5 - SS
The CJMCU-1293 pin #1 +5V should be connected to 3V3.
The CJMCU-1293 pin #2 GND should be connected to GND.
The CJMCU-1293 pin #3 SCLK should be connected to GPIO18 - SCK.
The CJMCU-1293 pin #4 SDI should be connected to GPIO23 - MOSI.
The CJMCU-1293 pin #5 SDO should be connected to GPIO19 - MISO.
The CJMCU-1293 pin #6 CSB should be connected to GPIO5 - SS.
The CJMCU-1293 pin #7 WCT should be connected to ???
The CJMCU-1293 pin #8 ALAB should be connected to ???
The CJMCU-1293 pin #9 DRDB should be connected to ???
Is the connection correct? Does anyone know where to connect ALAB (which should be alarm signal) and DRDB (which should be data ready signal)?
I found only this library (GitHub - Protocentral/protocentral-ads1293-arduino: Arduino library for the Protocentral ADS1293 breakout board) for Arduino. Will it work even when my board is not Protocentral but CJMCU?
Thank you.
Alex.
