CJMCU 6701 gsr sensor
I am trying to read GSR values from Generic CJMCU 6701 Arduino compatible sensor and Arduino UNO.
Following are the connections I have tried -
Sensor -> Arduino
+5V ->+5V
GND->GND
OUT -> A0
CS-> D10
MIS->D12
SCK-> D13
I wrote the following code to read the values -
#include <SPI.h>
int sensor_in =A0;
int raw=0;
int Vin=5;
float Vout=0;
float gsr=0;
  pinMode(12, INPUT); //MISO
  pinMode(13, OUTPUT); //CLOCK PIN
  digitalWrite(10, HIGH);  // ensure Slave select stays high
  SPI.begin();
  // enable Slave Select
  digitalWrite(10, LOW); // enable communication with slave
  raw= SPI.transfer(0x00);// read from sensor
  Serial.println(raw); // display reading on serial monitor
  // disable Slave
  Vout = (Vin * raw) / 1023;    // Convert Vout to volts
  gsr = 100*(1 / ((Vin / Vout) - 1));
  Serial.println(gsr);
The only values being displayed is 0. Please help me to rectify it and/or share any related resources that might be useful.
I have the same problem reading this sensor. Did you solve the problem. I tried to use Mcp320x library, but it does not work
This code very nice:
const int GSR=A0; //
int sensorValue=0; //
int gsr_average=0; //
void setup(){
void loop(){
long sum=0;
for(int i=0;i<10;i++)
sensorValue=analogRead(GSR);
sum += sensorValue;
delay(5); }
gsr_average = sum/10;
Serial.println(gsr_average);
Finger plates and code I took from the sensor: Grove - GSR Sensor | Seeed Studio Wiki
