Frankly, I suck at coding (only know very basic Python, not even Arduino), and I've been using AI to 'code'. Needless to say, not going great. I've tried to edit the code (two quick claps for servo to move one direction 5 degrees then back after a second, and then another two claps for it to move the other direction 5 degrees then back after a second) and it just hasn't been working. And I know my wiring is correct since the servo IS moving, it's just not moving correctly... at all. The project is due Friday, so I need some help fast lol
Here's the most updated code (still not working):
#include <Servo.h>
Servo myServo; // Create a servo object
const int soundSensorPin = A0;
const int servoPin = 9;
int soundLevel = 0;
int previousSoundLevel = 0;
int clapThreshold = 50;
int clapCount = 0;
int servoPosition = 0;
bool direction = true;
unsigned long lastClapTime = 0;
unsigned long clapInterval = 1000;
bool servoMoved = false;
myServo.attach(servoPin);
myServo.write(servoPosition);
soundLevel = analogRead(soundSensorPin);
Serial.println(soundLevel);
if (abs(soundLevel - previousSoundLevel) > clapThreshold) {
unsigned long currentTime = millis();
if (currentTime - lastClapTime < clapInterval) {
clapCount++;
previousSoundLevel = soundLevel;
lastClapTime = currentTime;
if (clapCount >= 2 && !servoMoved) {
if (direction) {
myServo.write(servoPosition + 5);
myServo.write(servoPosition - 5);
direction = !direction;
clapCount = 0;
servoMoved = true;
if (servoMoved && (millis() - lastClapTime) > clapInterval) {
servoMoved = false;
delay(50);
My eyes are crossing badly trying to understand your code. Not alarming, no worries. It looks plausible but you are flying blind.
Try placing serial print statements liberally strewn about to print the value of key bribes variables and confirm they are plausible and properly informing the flow through the code.
+1. I would say any time even looking into it would be well spent.
There may be some benefit to seeing the original sketch work, but there is no doubt that anything even a bit more complicate would be easier to do with the state machine approach.
Here is an example with the state machine following the approach from my tutorial and the above state machine description.
I replaced the sound sensor with a short potentiometer, so move it to the right to go above the threshold and back to the left and do that twice to get the "double clap" effect.
I think this illustrates how more readable a code can be using the right coding structure.
click to see the code
https://europe1.discourse-cdn.com/arduino/original/4X/0/5/9/05969069926a464e23c946bc115a75e89a83adfa.png
code is placed under the MIT license
Copyright (c) 2025 J-M-L
For the Arduino Forum : https://forum.arduino.cc/u/j-m-l
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
#include <Servo.h>
const byte soundSensorPin = A0;
const byte servoPin = 9;
const int clapThreshold = 900;
const unsigned long clapInterval = 1000;
const unsigned long servoInterval = 500;
const int servoPosition = 90;
int deltaPos = 50; // should be 5° but 50° is more visible
unsigned long t0;
enum {IDLE, FIRST_CLAP, ACTION} state = IDLE;
bool clapDetected() {
static bool previousClapDetected = false;
bool clapDetected = analogRead(soundSensorPin) >= clapThreshold;
if (not previousClapDetected && clapDetected) {
previousClapDetected = true;
return true;
previousClapDetected = clapDetected;
return false;
switch (state) {
case IDLE:
if (clapDetected()) {
t0 = millis();
state = FIRST_CLAP;
case FIRST_CLAP:
t0 = millis();
myServo.write(servoPosition + deltaPos);
state = ACTION;
} else if (millis() - t0 >= clapInterval) state = IDLE;
case ACTION:
if (millis() - t0 >= servoInterval) {
deltaPos = -deltaPos;
state = IDLE;
PS/ @arduinofella May be I left a bug intentionally, so not something to copy and give to the teacher... She/He will find out pretty quickly you cheated and copied it from here.
Wait… theoretically I could just have the servo rotate for a certain amount of time at a certain speed in one direction, achieving the same result (albeit less precise), right? Problem is, no idea where to even start on coding THAT.
and this would make the attempt to wrangle a continuous rotation servo into being what it is not:
myServo.write(120); // moving CW at a clip. Or is that CCW
delay(318);
// myServo.write(90); // stop
myServo.write(60); // moving CCW at a clip.
delay(318);
where I have 318 as the time and 30 as the speed. 90 +/- 30. Adjust to taste.
I don't have one, so it will be interesting to see how it works.
Or… buy another servo, a non-continuous rotation servo.
