clap on, clap off
Heey. im trying to make a clap on clap off to my arduino.
the idea is to make a simple read on a mic and the arduino will then turn on an LED
i found this circuit: http://blog.makezine.com/archive/2008/03/explody-easter-peeps-high.html (only look at the left pard of the diagram)
it looks like this one runs on high sounds so i thought it could work with a clap but for some reason i cant get a read, tho i made an exact copy og the scematiks BUT... i cant find the code for this device
if anyone could help with either: a code that can make a read from the mic or a new cercuit the will work that is simple enough and a short code to get me started
o i thought it could ude with a clap but for some readon i cant get a read tho i made an exact copy og the scematiks
Can you run that one through Google translate, please
Have you seen this project on the playground : - http://www.arduino.cc/en/Tutorial/KnockSensor -
Think it almost does what you want.
You need to amplify mic signal at least 100x. Look for electret mic shield with on-board OPA,
like this one: SparkFun Electret Microphone Breakout - BOB-12758 - SparkFun Electronics
robtillaart:
well it wont even accept that code..
At void setup it wont accept:
beginSerial(9600);
And in void loop it wont accept:
printString("Knock!");
printByte(10);
printByte(13);
Magician:
like this one: http://www.sparkfun.com/products/9964
I cant get those shields because its a school project. But what conflikts me is that if this person could get this to work why to i then have to amp the sound 100 times? what do i get out if it?
and thank you all for helping :slight_smile:
What you are using as audio source? In a link you posted above it says "headphone level audio signal", and it's not the case for separate mic..
beginSerial(9600);
printByte(10);
printByte(13);
"thou should anda learn to speak the tongue of the elderly"
Seriously, it is an older article which is not updated to the lastest version of all the libraries.
beginSerial() -> Serial.begin()
printString() , printByte() -> Serial.print() Serial.println()
You should get it running ...
