Clarification needed on FPGA bitstream flashing
  1. I am not using J11- JTAG pins
  2. When i use ".ttf" file to program SAMD and FPGA using Arduino IDE, where does the fpga bitstream stored ? IS it stored in FPGA -EPCQ16 SPI Flash ?
This website says in section III - ".ttf" file is mapped to spi FLASH. I need clarification on this if its correct or not.
  1. I used USBBLASTER 1.0.0 library on SAMD, and installed intel usb blaster to work it out with quartus. so in this mode when i program ".sof" file why the bitstream doesnot stays after system reset?
after some searching i found someone told about using J11 and JTAG blaster method:
now in vidor schematic SAMD and FPGA both are connected on same JTAG - J11, so at this point i dont understand, if i used J11 and upload bitstream to FLASH, why its not possible through SAMD - USBBLASTER ?
I know FPGA contains JTAG but does it also contains JTAG with SPI IP ? i want to understand what's the difference between no 2 and 3 i described.
Thanks :slight_smile:
