I am making a project which controls a servo based on the data from the rf input.When I compile it (the program uses both the servo and virtual wire library) it shows the error:
Arduino: 1.6.4 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Servo\avr\Servo.cpp.o: In function __vector_17': F:\Program Files\Arduino\libraries\Servo\src\avr/Servo.cpp:81: multiple definition of __vector_17'
VirtualWire\VirtualWire.cpp.o:C:\Users\Customer\Documents\Arduino\libraries\VirtualWire/VirtualWire.cpp:571: first defined here
f:/program files/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.8.1/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
collect2.exe: error: ld returned 1 exit status
Error compiling.
Without the virtual wire library included, it does not show any error.What could have happened?
Are all the functions and commands same?I took that they are same for both the servo and servotimer2 library and got the following errors while compiling:
In file included from rx.ino:3:0:
F:\Program Files\Arduino\libraries\ServoTimer2/ServoTimer2.h:41:17: error: conflicting declaration 'typedef uint8_t boolean'
typedef uint8_t boolean;
In file included from C:\Users\Customer\Documents\Arduino\libraries\VirtualWire/VirtualWire.h:146:0,
from rx.ino:1:
F:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:117:14: error: 'boolean' has a previous declaration as 'typedef bool boolean'
typedef bool boolean;
rx:10: error: 'Servo' does not name a type
rx:11: error: 'Servo' does not name a type
rx:12: error: 'Servo' does not name a type
rx:13: error: 'Servo' does not name a type
rx.ino: In function 'void setup()':
rx:27: error: 'servo1' was not declared in this scope
rx:28: error: 'servo2' was not declared in this scope
rx:29: error: 'servo3' was not declared in this scope
rx:30: error: 'servo4' was not declared in this scope
rx.ino: In function 'void loop()':
rx:62: error: 'servo1' was not declared in this scope
rx:67: error: 'servo2' was not declared in this scope
rx:72: error: 'servo3' was not declared in this scope
rx:77: error: 'servo4' was not declared in this scope
enabled in File > Preferences.
Here is the error message that I get after doing what you told me.The number of error messages has decreased,but there is still one more.
from rx.ino:1:
Error compiling.
Did you look at the example in the library folder?
The emoticon comes from there being this line in the code:
servo4.attach(8);
.... and the browser takes the 8) to be the 8). So you should select your code and hit the </> icon above the to wrap it in [code][/code] tags so then your
I think this problem is due to your use of Arduino IDE 1.6.4. Unfortunately the Arduino folks are not good at backwards compatibility. There is probably a fix, but I don't know what it is.
A simple solution is to use Arduino IDE 1.5.6 - you can easily have a few different versions of the IDE on your PC.
when i use ServoTimer2 header file without using VirtualWire it does not show any error but when i upload on board motor is not work so give me solution
maheshjsmr:
Post your program so that we can see what you can see.
And please use the code button </> so your code looks like this and is easy to copy to a text editor
