'class AsyncWebServer' has no member named 'arg'
I tried to program the car control using web on esp8266, this error came up 'class AsyncWebServer' has no member named 'arg'
//ESP
// Import required libraries
#include <Arduino.h>
#ifdef ESP32
#include <WiFi.h>
#include <AsyncTCP.h>
#elif defined(ESP8266)
#include <ESP8266WiFi.h>
#include <ESPAsyncTCP.h>
#endif
#include <ESPAsyncWebServer.h>
#include <FS.h>
/* Put your SSID & Password */
const char* ssid = "Car";  // Enter SSID here
const char* password = "12345678";  //Enter Password here
/* Put IP Address details */
IPAddress local_ip(192,168,1,1);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,255,0);
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
//int in1 = D5;
//int in2 = D6;
//int motor_speed = 0;
void handleJSData(){
  boolean yDir;
  int x = server.arg(0).toInt() * 10;
  int y = server.arg(1).toInt() * 10;
  int aSpeed = abs(y);
  int bSpeed = abs(y);
  //set the direction based on y being negative or positive
  if ( y < 0 ){
    yDir = 0;
  else {
    yDir = 1;
  //adjust to speed of each each motor depending on the x-axis
  //it slows down one motor and speeds up the other proportionately
  //based on the amount of turning
  aSpeed = constrain(aSpeed + x/2, 0, 1023);
  bSpeed = constrain(bSpeed - x/2, 0, 1023);
  //use the speed and direction values to turn the motors
  //if either motor is going in reverse from what is expected,
  //just change the 2 digitalWrite lines for both motors:
  //!ydir would become ydir, and ydir would become !ydir
  //MotorA
  Serial.print(0);
  Serial.print(1);
  Serial.print(4);
  //MotorB
  Serial.print(2);
  Serial.print(3);
  Serial.print(5);
  //return an HTTP 200
  server.send(200, "text/plain", "");
void setup(){
  // Serial port for debugging purposes
  if(SPIFFS.begin()==true) {
    Serial.println("SPIFFS initialised OK");
  //pinMode(in1, OUTPUT);
  //pinMode(in2, OUTPUT);
  WiFi.softAP(ssid, password);
  WiFi.softAPConfig(local_ip, gateway, subnet);
  delay(100);
  // Route for root / web page
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send(SPIFFS, "/index.html", "text/html");
  server.on("/assets/css/foundation.css", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send(SPIFFS, "/assets/css/foundation.css", "text/css");
  server.on("/assets/js/vendor.js", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send(SPIFFS, "/assets/js/vendor.js", "text/js");
  server.on("/assets/js/foundation.js", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send(SPIFFS, "/assets/js/foundation.js", "text/js");
  server.serveStatic("/assets/js/virtualjoystick.js", SPIFFS, "/assets/js/virtualjoystick.js");
  //call handleJSData function when this URL is accessed by the js in the html file
  server.on("/jsData.html", handleJSData);
  // Start server
  server.begin();
void loop(){
Please show the entire error message.
There’s even a dedicated button in the IDE to cut the correct content
Your picture is useless, follow the forum guidelines and post accordingly using code tags.
