Hi all,
I am trying to send a HTTPS Get request:
I am using the code that is in the link above:
* HTTPS Secured Client GET Request
* Copyright (c) 2019, circuits4you.com
* All rights reserved.
* https://circuits4you.com
* Connects to WiFi HotSpot. */
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPClient.h>
/* Set these to your desired credentials. */
const char *ssid = "SSID"; //ENTER YOUR WIFI SETTINGS
const char *password = "password";
//Link to read data from https://jsonplaceholder.typicode.com/comments?postId=7
//Web/Server address to read/write from
const char *host = "jsonplaceholder.typicode.com";
const int httpsPort = 443; //HTTPS= 443 and HTTP = 80
//SHA1 finger print of certificate use web browser to view and copy
const char fingerprint[] PROGMEM = "B7 CB 1D 1B 02 72 1D 0E 89 A7 94 92 55 38 A7 37 9B 5D CD C4";
// Power on setup
WiFi.mode(WIFI_OFF); //Prevents reconnection issue (taking too long to connect)
WiFi.mode(WIFI_STA); //Only Station No AP, This line hides the viewing of ESP as wifi hotspot
WiFi.begin(ssid, password); //Connect to your WiFi router
Serial.println("");
Serial.print("Connecting");
// Wait for connection
Serial.print(".");
//If connection successful show IP address in serial monitor
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); //IP address assigned to your ESP
// Main Program Loop
WiFiClientSecure httpsClient; //Declare object of class WiFiClient
Serial.println(host);
Serial.printf("Using fingerprint '%s'\n", fingerprint);
httpsClient.setFingerprint(fingerprint);
httpsClient.setTimeout(15000); // 15 Seconds
Serial.print("HTTPS Connecting");
int r=0; //retry counter
while((!httpsClient.connect(host, httpsPort)) && (r < 30)){
delay(100);
Serial.print(".");
r++;
if(r==30) {
Serial.println("Connection failed");
else {
Serial.println("Connected to web");
String ADCData, getData, Link;
int adcvalue=analogRead(A0); //Read Analog value of LDR
ADCData = String(adcvalue); //String to interger conversion
//GET Data
Link = "/comments?postId=" + ADCData;
Serial.print("requesting URL: ");
Serial.println(host+Link);
httpsClient.print(String("GET ") + Link + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
Serial.println("request sent");
while (httpsClient.connected()) {
String line = httpsClient.readStringUntil('\n');
if (line == "\r") {
Serial.println("headers received");
Serial.println("reply was:");
Serial.println("==========");
String line;
while(httpsClient.available()){
line = httpsClient.readStringUntil('\n'); //Read Line by Line
Serial.println(line); //Print response
Serial.println("closing connection");
delay(2000); //GET Data at every 2 seconds
I get this error:
'class axTLS::WiFiClientSecure' has no member named 'setFingerprint'
About this piece of code:
What have I done wrong? Any help with this would be awesome!
Thanks,
Zeb
