class by ref
Hi.
im struggling to get an object to pass into another object by reference rather then value. in the main setup i want to construct my first object, then pass it to the second object and it be the same object when i reference it later.
hope that makes some sense.
i have produced this simplified version to kind of show what i mean
Test
the object that will be passed and i want to be the same object reference
it has and integer and a method to add 1 to the integer
class Test{
  public:
  int i;
  Test(){
    i=0;
  void addone(){
    i=i+1;
Test Container
this is the bigger object that i want to be passed the test object as a reference.
class TestContainer{
  public:
  Test theTest;
  //i thought the & should make it ref
  TestContainer(Test &_theTest)
    //i've tried an & here but wont compile
    theTest = _theTest ;
void setup(){
  Serial.begin(57600);
  //setup the test object
  Test theTest = Test();
  //print its value - should be 0
  Serial.print("1 theTest.i : ");
  Serial.println(theTest.i);
  //add 1 to the value
  theTest.addone();
  //print it, it should now be 2
  Serial.print("2 theTest.i : ");
  //put the object inside another object
  TestContainer tc = TestContainer(theTest);
  //test to see its value is the same as before
  Serial.print("3 tc.theTest.i : ");
  Serial.println(tc.theTest.i);
  //add 1 to the test object
  theTest.addone();
  //test to make sure its added 1
  Serial.print("4 theTest.i : ");
  //make sure the container object also is the same.
  //for some reason its not
  Serial.print("5 tc.theTest.i : ");
void loop(){
i just need to know how i can pass theTest to tc and it be the same object
thanks for any help.
No, it doesn't.
Then why is theTest's type Test?
You should be using pointers. theTest should be defined like so:
Test *theTest; // currently points to nothing
Then, theTest can be made to point to _theTest, with also should be a Test *.
Then, you can call the constructor with the address of (not a reference to) an object.
Nonsense. You NEVER call the constructor directly. That should be:
  Test theTest;
should be:
  TestContainer tc = TestContainer(&theTest);
after you make the TestContainer constructor take a pointer.
  public:
  Test & theTest;
  TestContainer(Test &_theTest) : theTest ( _theTest) {}
PaulS has some good points, but you can pass by reference. As he says, construct it like this:
  Test theTest;
Output:
1 theTest.i : 0
2 theTest.i : 1
3 tc.theTest.i : 1
4 theTest.i : 2
5 tc.theTest.i : 2
Thanks alot to both of you.
sorry it didnt make sense.
I can see some silly stuff ive done there, but i can also how i can get the reference/address of passed.
thanks
stuart
sjeffrey:
Oh, aye.
