Class composition, passing by reference - what I do wrong?
I'm writing a class "Clock" (see attachments) which implements a general clock functionality. I want this class to be reusable in different projects, so it has to have some access to a variables of the main program.
Class TimestampProvider is a way to use a global timestamp variable as oppose to call "millis()" inside the class "Clock". It is an abstract class and it has to be subclassed in a particular program.
#ifndef TIMESTAMPPROVIDER_H_
#define TIMESTAMPPROVIDER_H_
class TimestampProvider {
public:
	virtual unsigned long getTimestamp() const = 0;
	virtual ~TimestampProvider(){};
#endif /* TIMESTAMPPROVIDER_H_ */
In the main program I make a subclass of TimestampProvider which is supposed to have an access to a global variables:
class MillisProvider : public TimestampProvider {
public:
	unsigned long int getTimestamp() const;
unsigned long int MillisProvider::getTimestamp() const {
	Serial.println("inside getTimestamp()");
	return 0;
Then I'm creating the objects:
MillisProvider msp;
Clock  clock(msp);
The problem is when in the loop I call a method of the class "Clock" which contains a call "timestamp.getTimestamp()" (for example "clock.increaseHours()") my Arduino resets.
Clock.cpp (928 Bytes)
Clock.h (537 Bytes)
I got it. The reference member timestamp must be initialized in the constructor initializer block, not in the body of the constructor.
