Hello, i have made some changes to the LiquidCrystal library, i made it with Gedit in mi Linux machine, i hace put the Library into the arduino Library folder and when i try to use my function in the code, gcc say that there is no member called my function name.
The problem comes when i try to use the function of autocenter, it say that there is no method iun the class and i am comparing with the others methods and is equal...
Thank you for your interest, but now it is working fine, i think that the problem was at the names i put to the original folder and the modified folder, because when i completely remove from /Arduino/Librarys/ the original folder, the enviroment was capable of compiling with the new functions.
I had the original library into /Arduino/Librarys/LiquidCrystal_old
and the new /Arduino/Librarys/Liquidcrystal
but the files has the same name for the to librarys and i suppose that gcc look for the file name everywhere into Librarys/ and do not matter where the file is.
Thank you for all, i will post the modified library as soon as I test it completely.
