I have a problem with the onEvent function from the WebSocketClient lib. Here is my code and my error message.
header:
#ifndef Lamp_Alexa_h
#define Lamp_Alexa_h
// including Amazon Alexa necessary libaries
#include <WebSocketsClient.h> // get it from https://github.com/Links2004/arduinoWebSockets/releases
#include <ArduinoJson.h> // get it from https://arduinojson.org/ or install via Arduino library manager
#include <StreamString.h>
// define parameters for sinric
#define API_ENDPOINT "http://sinric.com"
#define HEARTBEAT_INTERVAL 300000 // 5 Minutes
class Lamp_Alexa{
public:
Lamp_Alexa(String apiKey, String deviceId);
void turnOn();
void turnOff();
void init();
private:
WebSocketsClient webSocket;
String state;
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length);
String _deviceId;
String _apiKey;
bool isConnected;
#endif
cpp:
#include "Lamp_Alexa.h"
Lamp_Alexa::Lamp_Alexa(String apiKey, String deviceId){
_deviceId = deviceId;
_apiKey = apiKey;
void Lamp_Alexa::init(){
// server address, port and URL
webSocket.begin("iot.sinric.com", 80, "/");
// event handler
webSocket.onEvent(this->webSocketEvent);
webSocket.setAuthorization("apikey", _apiKey);
// try again every 5000ms if connection has failed
webSocket.setReconnectInterval(5000);
void Lamp_Alexa::webSocketEvent(WStype_t type, uint8_t * payload, size_t length){
switch(type) {
case WStype_DISCONNECTED:
isConnected = false;
Serial.printf("[WSc] Webservice disconnected from sinric.com!\n");
case WStype_CONNECTED: {
isConnected = true;
Serial.printf("[WSc] Service connected to sinric.com at url: %s\n", payload);
Serial.printf("Waiting for commands from sinric.com ...\n");
case WStype_TEXT: {
Serial.printf("[WSc] get text: %s\n", payload);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject((char*)payload);
String deviceId = json ["deviceId"];
String action = json ["action"];
if(action == "setPowerState") { // Switch or Light
String value = json ["value"];
if(value == "ON") {
else if(action == "SetColor") {
// Alexa, set the device name to red (0) / green (120) / blue (240)
// get text: {"deviceId":"xxxx","action":"SetColor","value":{"hue":0,"saturation":1,"brightness":1}}
String hue = json ["value"]["hue"];
String saturation = json ["value"]["saturation"];
String brightness = json ["value"]["brightness"];
Serial.println("[WSc] hue: " + hue);
Serial.println("[WSc] saturation: " + saturation);
Serial.println("[WSc] brightness: " + brightness);
if(hue == "0"){
else if(hue == "120"){
else if(hue == "240"){
}// end SetColor
else if(action == "setBrightness") {
}// end brightness
else if(action == "AdjustBrightness") {
else if (action == "test") {
Serial.println("[WSc] received test command from sinric.com");
case WStype_BIN:
Serial.printf("[WSc] get binary length: %u\n", length);
error message:
C:\Users\xanix\AppData\Local\Temp\arduino_build_362415\sketch\Lamp_Alexa.cpp: In member function 'void Lamp_Alexa::init()':
Lamp_Alexa.cpp:13: error: no matching function for call to 'WebSocketsClient::onEvent(<unresolved overloaded function type>)'
C:\Users\xanix\AppData\Local\Temp\arduino_build_362415\sketch\Lamp_Alexa.cpp:13:41: note: candidate is:
In file included from C:\Users\xanix\AppData\Local\Temp\arduino_build_362415\sketch\Lamp_Alexa.h:11:0,
from C:\Users\xanix\AppData\Local\Temp\arduino_build_362415\sketch\Lamp_Alexa.cpp:1:
C:\Users\xanix\Documents\Arduino\libraries\arduinoWebSockets-2.1.1\src/WebSocketsClient.h:66:14: note: void WebSocketsClient::onEvent(WebSocketsClient::WebSocketClientEvent)
void onEvent(WebSocketClientEvent cbEvent);
C:\Users\xanix\Documents\Arduino\libraries\arduinoWebSockets-2.1.1\src/WebSocketsClient.h:66:14: note: no known conversion for argument 1 from '<unresolved overloaded function type>' to 'WebSocketsClient::WebSocketClientEvent {aka std::function<void(WStype_t, unsigned char*, unsigned int)>}'
Lamp_Alexa.cpp:14: error: no matching function for call to 'WebSocketsClient::setAuthorization(const char [7], String&)'
C:\Users\xanix\AppData\Local\Temp\arduino_build_362415\sketch\Lamp_Alexa.cpp:14:47: note: candidates are:
C:\Users\xanix\Documents\Arduino\libraries\arduinoWebSockets-2.1.1\src/WebSocketsClient.h:82:14: note: void WebSocketsClient::setAuthorization(const char*, const char*)
void setAuthorization(const char * user, const char * password);
C:\Users\xanix\Documents\Arduino\libraries\arduinoWebSockets-2.1.1\src/WebSocketsClient.h:82:14: note: no known conversion for argument 2 from 'String' to 'const char*'
C:\Users\xanix\Documents\Arduino\libraries\arduinoWebSockets-2.1.1\src/WebSocketsClient.h:83:14: note: void WebSocketsClient::setAuthorization(const char*)
void setAuthorization(const char * auth);
C:\Users\xanix\Documents\Arduino\libraries\arduinoWebSockets-2.1.1\src/WebSocketsClient.h:83:14: note: candidate expects 1 argument, 2 provided
Bibliothek arduinoWebSockets-2.1.1 in Version 2.1.1 im Ordner: C:\Users\xanix\Documents\Arduino\libraries\arduinoWebSockets-2.1.1 wird verwendet
Bibliothek ESP8266WiFi in Version 1.0 im Ordner: C:\Users\xanix\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi wird verwendet
Bibliothek ArduinoJson in Version 5.13.2 im Ordner: C:\Users\xanix\Documents\Arduino\libraries\ArduinoJson wird verwendet
Bibliothek Adafruit_NeoPixel in Version 1.1.6 im Ordner: C:\Users\xanix\Documents\Arduino\libraries\Adafruit_NeoPixel wird verwendet
Bibliothek Hash in Version 1.0 im Ordner: C:\Users\xanix\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\Hash wird verwendet
exit status 1
