Any solution?
You might need a pull up resistor (eg 4K) between +5V and the dataline.
How long is the line between the arduino and the sensor?
Rob
Any solution?
Rob
updated the code to 0.1.03;
As allways comments still welcome
One suggestion for the code is to replace or augment the read11 and read22 routines by one unique read routine that would detect which one it is and return 11 or 22 in chk.
I'm not sure it is so easy, but for example, having both [2] and [4] zero with a DHT22 should almost never happen, right ?
They are the lsB if I get it right, so humidity has to be 25.6, 51.2 or 76.8 for byte[4] to be zero. Then in that case temperature has to be precisely 25.6 etc. Pretty unusual.
To be even more confident, there could be a "confidence" variable based on previous measurements: increase/decrease a uint8_t counter for every non/zero value with saturation @ +127/-128, so DHT11 goes from zero @reset to -128 and DHT22 to +127.
Another thing is to replace the double by an int in tenths of degrees. So for DHT11 it would return array[0]*10;
Don't mix error state with configuration information. That said, one could make a function int determine() that does just that. Typically it is called just once and remembered - you just needs one byte to keep the 11/22 flag of 8 sensors.
possible but one could only account readings for which [2] and [4] are zero AND the checksum is OK.
Assuming a valid reading, both numbers have one decimal place 0..9 =>10 possible values. This implies that the chance would be about one in hundred for an individual reading to have two 0's as decimal. That is a small chance but too big imho to make a reliable determine() function, it is definitely not deterministic. Multiple readings with will improve this number but as the device needs 2 seconds between readings so determine() function becomes quite time consuming.
Note that especially for the DHT11 one can use a (running) average to get a higher precision - and thus decimal places ).
Hi robtllaart
robtillaart: updated the code to 0.1.03;
- added code to reflect faulty reading in temperature (-999) and humidity (-999) if there is a timeout. So if a sketch does not test the return value of read11() or read22() you will still see it clearly.
I would change the follow code in read22() and read11() functions from
int rv = read(pin);
if (rv != 0)
to
int rv = read(pin);
if (rv != DHTLIB_OK)
No functionally change but improves readability.
That is very keen eye! I will change it asap
Thanks, Rob
updated on the playground to version 0.1.04
Rob
robtillaart: + added #define DHTLIB_INVALID_VALUE -999 to remove that magic number from the lib too.
Rob
Wow! Very good too.
Thanks for this code and best regards, Benito.
Nice library. However, it does not work correctly for negative temperatures. I’m using version 0.1.04. When a negative temperature is measured the class will return DHTLIB_ERROR_CHECKSUM. The problem is at line 74 in dht.cpp. Here bits[2] is modified, which makes the checksum calculation incorrect. There are, of course, many ways to fix the problem. I have fixed it by changing the code in the following way.
Old Code:
int sign = 1;
if (bits[2] & 0x80) // negative temperature
bits[2] = bits[2] & 0x7F;
sign = -1;
temperature = sign * word(bits[2], bits[3]) * 0.1;
New Code:
temperature = word(bits[2]&0x7F, bits[3]) * 0.1;
temperature = -1.0 * temperature;
temperature = word(bits[2], bits[3]) * 0.1;
Thanks for the library, and with this fix it is just perfect for me!
Thanks for this feedback, I'll fix it a.s.a.p.
updated the playground article to include the patch above.
Thanks again!
No idea why someone wants to write code if there already exists a perfectly fine library... but... I just checked in a DHT library with the following features: - Support for DHT11 and DHT22, AM2302, RHT03 - Auto detect sensor model - Very low memory footprint - Very small code
https://github.com/markruys/arduino-DHT
Maybe useful for someone - feel free to report bugs.
Well done Mark,
Looked at your code and it looks like a decent piece of work. It is similar to a version I'm working on and yes I better stop with that version ;)
The difference between your code and mine is that your code encapsulated an individual sensor while mine encapsulates the handshake so multiple sensors use one instance. Footprint will differ too but not measured. I like the auto-detect functionality, well done
There is one improvement I want to propose to your class which I had build in my draft. If there is a time-out I would return the previous values instead of NaN. The error flag should still be the same. To do this the results temperature & humidity should have class scope.
If the program requests the temperature too fast it just gets the prev value which is seldom far from the actual value (instead of a NaN)
something like this
DHT::DHT_t DHT::read()
// don't poll the sensor too often
// - Max sample rate DHT11 is 1 Hz (duty cycle 1000 ms)
// - Max sample rate DHT22 is 0.5 Hz (duty cycle 2000 ms)
unsigned long startTime = millis();
if ( (startTime - lastReadTime) < getMinimalDelay() ) // use the internal function
results.error = ERROR_TOO_QUICK;
return results; // returns previous temperature and humidity
lastReadTime = startTime;
results.error = ERROR_NONE;
results.temperature = NAN;
results.humidity = NAN;
// Request sample
the way I coded the interface was 3 public functions
float DHT::getHumidity()
if ( millis() - lastReadTime > 2000 || status != ERROR_NONE ) // time to refresh or to retry
status = read(); // fetch new hum & temp
lastReadTime = millis();
return humidity;
float DHT::getTemperature()
status = read(); // status and read() are private
return temperature; // private member
float DHT::getStatus()
status = read(); // fetch new data
typing this you could also add the "retry" condition.
my 2 cents, regards / groeten, Rob
Just a few questions while checking both DHT versions:
Rob:
Mark:
Further:
Please comment 8)
Rob: - Has a delay of 20msec for both DHT11 and DHT22. - Uses a counter in the while to break out of the while in case the pin does not change
The counter makes the loop fool proof.
The 20 mSec is to make code as similar as possible for both sensors, Mark optimizes the code to the detail of the datasheet which is good better ;)
I am using multiple DHT22's on different pins. Which library would be most RAM efficient?
Not tested, I expect the lib from mark be smaller for a single sensor but my lib can support multiple with one instance. Somewhere there must be a break even point. It would be very informative if you could provide some numbers
- Is the 800usec the right delay for the DHT22? If so, it saves me 5*19msec = 75msec of doing nothing, which is a lot using NilRTOS/ChibiOS RTOSses...
800usec - check datasheet.
In an RTOS one should schedule another thread when delay is called, to return /test later. In pseudocode
delay(uint32_t ms)
wakeUpThisThread(ms);
switchThread();
This way one could always use the waiting time effective. (disclaimer, no RTOS expert)
Thanks Rob for your suggestions. I just commited a new version of the library with the following changes:
Code example:
#include "DHT.h"
DHT dht = DHT(2); // data pin 2, auto detect DHT model
dht.setup();
delay(dht.getMinimalDelay());
Serial.print(dht.getHumidity(), 1);
Serial.print("\t");
Serial.println(dht.getTemperature(), 1);
MarsWarrior: Just a few questions while checking both DHT versions:
Mark: - Has a delay of 18msec for the DHT11 and 800usec for the DHT22. - Uses an endless while loop, so if the pin does not change --> Arduino in endless loop!
Further: - I am using multiple DHT22's on different pins. Which library would be most RAM efficient? - Is the 800usec the right delay for the DHT22? If so, it saves me 5*19msec = 75msec of doing nothing, which is a lot using NilRTOS/ChibiOS RTOSses...
Please comment 8)
[quote author=Mark Ruys link=topic=58531.msg1274792#msg1274792 date=1370985148]
- My library won't hang. The endless loop you mention has a return statement which is called after 85 usec.
- Per DHT instance, you need 18 bytes of data~~, perhaps a little more overhead, I would need to measure to give a hard number~~. So no problem to run a lot of DHT sensors (tried two myself). The advantage of having an instance per sensor is that you can read out them in parallel. On the other hand, it would be straightforward to alter setup() to something like setup(pin, model) and then you could reuse the instance. But not sure if the effort is worth the 18*(sensor-1) bytes...
Ah! You are right, I misread some of the C++ code :zipper_mouth_face: 18 bytes is not very much indeed. Thanx!
Rob Tillaart suggested that I created a another thread for the new library, so I did: http://forum.arduino.cc/index.php?topic=171677.0. This way we keep this thread focussed on Rob's great work.
I reworked my library and just commited all my changes for some more features.
Hello Rob, I tried this library on Arduino Due and it seems since its SAM series processor the includes for AVR wont work (avr/io.h etc). Can you suggest changes to make this library compile and work on Arduino Due boards .
Thanks for the help
