Class for DHT11, DHT21 and DHT22 (temperature & humidity)
Thanks Rob for your suggestions. I just commited a new version of the library with the following changes:
  • Removed ERROR_TOO_QUICK. If you poll too often, you just get cached data
  • Removed read() and added getTemperature() and getHumidity(). This gives a much cleaner interface for the users.
  • Fixed DHT11 detection. Removed the detection from the class constructor to a seperate setup()
Code example:
#include "DHT.h"
DHT dht = DHT(2); // data pin 2, auto detect DHT model
  dht.setup();
  delay(dht.getMinimalDelay());
  Serial.print(dht.getHumidity(), 1);
  Serial.print("\t");
  Serial.println(dht.getTemperature(), 1);
MarsWarrior: Just a few questions while checking both DHT versions:
Rob: - Has a delay of 20msec for both DHT11 and DHT22. - Uses a counter in the while to break out of the while in case the pin does not change
Mark: - Has a delay of 18msec for the DHT11 and 800usec for the DHT22. - Uses an endless while loop, so if the pin does not change --> Arduino in endless loop!
Further: - I am using multiple DHT22's on different pins. Which library would be most RAM efficient? - Is the 800usec the right delay for the DHT22? If so, it saves me 5*19msec = 75msec of doing nothing, which is a lot using NilRTOS/ChibiOS RTOSses...
Please comment 8)
  • 800usec for a DHT22 is according to the datasheets I found. And it works.
  • My library won't hang. The endless loop you mention has a return statement which is called after 85 usec.
  • Per DHT instance, you need 18 bytes of data~~, perhaps a little more overhead, I would need to measure to give a hard number~~. So no problem to run a lot of DHT sensors (tried two myself). The advantage of having an instance per sensor is that you can read out them in parallel. On the other hand, it would be straightforward to alter setup() to something like setup(pin, model) and then you could reuse the instance. But not sure if the effort is worth the 18*(sensor-1) bytes...
[quote author=Mark Ruys link=topic=58531.msg1274792#msg1274792 date=1370985148]
  • 800usec for a DHT22 is according to the datasheets I found. And it works. [/quote]Nice. Will try with the current lib I'm using!
Ah! You are right, I misread some of the C++ code :zipper_mouth_face: 18 bytes is not very much indeed. Thanx!
Rob Tillaart suggested that I created a another thread for the new library, so I did: http://forum.arduino.cc/index.php?topic=171677.0. This way we keep this thread focussed on Rob's great work.
I reworked my library and just commited all my changes for some more features.
Hello Rob, I tried this library on Arduino Due and it seems since its SAM series processor the includes for AVR wont work (avr/io.h etc). Can you suggest changes to make this library compile and work on Arduino Due boards .
Thanks for the help
Added support for the DHT21 (AM2301) today - http://playground.arduino.cc/Main/DHTLib -
datasheet DHT21: - http://www.electrodragon.com/w/images/6/6f/DHT21.pdf -
Seen at: - http://www.electrodragon.com/?product=am2301-dht21-digital-temperature-humidity-sensor -
The DHT21 has the same handshake as the DHT11 and DHT22. The translation to real values (TEMP/RH) is different again.
As I do not have the sensor yet I have not tested it, so all feedback is welcome.
As always remarks and feedback is welcome.
Sorry for the late reaction, I missed it somehow.
sanhardik: Hello Rob, I tried this library on Arduino Due and it seems since its SAM series processor the includes for AVR wont work (avr/io.h etc). Can you suggest changes to make this library compile and work on Arduino Due boards .
Thanks for the help
I have no Due operational, but you should check the private read() function. It uses a #define TIMEOUT 10000 which is tuned for the 16Mhz UNO. so it will trigger too fast on an DUE. As the Due is 84 MHz ==> 5.25 x as fast, you should adjust the TIMEOUT to 60000 (at least)
A more permanent solution should derive a clock dependant timeout like this
#define TIMEOUT (F_CPU/1600)
please give it a try.
update: Got mail today, DHT21 testing is in progress, the code in the lib seems not to decode right.
The decoding was based upon this hint from the datasheet: "DATA=8 bit integral RH data+8 bit decimal RH data+8 bit integral T data+8 bit decimal T data+8 bit check-sum " HEX dumps of received bytes have a correct CRC. A new decoding scheme is derived from the dumps and currently under test.
I have some problems with the library. I have an arduino due and an am2301 sensor (DHT21). The temperature at the moment that I tested the sensor was more or less 22 degrees. I set up: #define TIMEOUT 52500 in dht.cpp
Data showned in dht_test.ino is: Humidity 2.3 Temperature 0.9
Any idea?? Thanks!
wifialex: I have some problems with the library. I have an arduino due and an am2301 sensor (DHT21). The temperature at the moment that I tested the sensor was more or less 22 degrees. I set up: #define TIMEOUT 52500 in dht.cpp
Any idea?? Thanks!
Yes, the code for the support of the DHT21 is experimental, based on hints in a datasheet (link see a few pages above) and just does not work yet.
Can you please access the DHT21 as if it was a DHT22 so use read22(pin) instead of read21(pin)?
I have strong indications that the formula for DHT21 and DHT22 are identical although the datasheet hinted otherwise. I have no confirmation yet and maybe you can confirm (as I do not have the DHT21 myself).
When my assumption is confirmed I can update the code.
I have just checked it using dht22 read. The measures are closed to real but there are errors: Humidity is lower than real Temperature is higher than real
Can you give exact figures, lower and higher are too subjective.
Low humidity is often mentioned as problem with the DHT sensors, temperature can depend on air flow but should be within 3C. In your code you can add an offset to adjust the temp to the real value. For humidity this will probably not work.
First of all, sorry for my delayed answer, but I was very busy. The first one pic sensor was calibrated two months ago, so it should be very accurate. The second one pic is DHT21 data
20130920_174238.jpg|2448x1836
20130920_174228.jpg|2448x1836
This proves that the DHT21 uses the same conversion as the DHT22. I will update the playground and the lib. The delta in temperature is within acceptable errors. You might add an offset to adjust.
Thanks for testing,
You are welcome, I added an offset -2º in temperature data
Thanks!
How did this library compare with the popular Adafruit one ? https://github.com/adafruit/DHT-sensor-library
In any case, maybe you add their lib to the other "Library list".
wifialex: You are welcome, I added an offset -2º in temperature data Thanks!
Do you (or others) think the library should support for a corrective offset?
e.g.
void setTempOffset(float delta);
float getTempOffset();
void setHumOffset(float delta);
float getHumOffset();
or in the constructor...
will work better if the library uses an object per sensor iso one object for all sensors. need a rewrite... something like * *DHT22 sensor1(pin, offset);
Updated the playground to version 0.1.08 major change - support for DUE (adaptive TIMEOUT).
Greetings, Thanks for the work. I am having problems with compiling the code. I have an UDOO and I am attempting to execute the code on the DUE side. I get the following error though. Any help would be greatly appreciated.
V/r
Derrick
DHT/dht.cpp.o: In function dht::read(unsigned char)': /home/ubuntu/Arduino/libraries/DHT/dht.cpp:116: multiple definition ofdht::read(unsigned char)' dht.cpp.o:dht.cpp:116: first defined here DHT/dht.cpp.o: In function dht::read22(unsigned char)': /home/ubuntu/Arduino/libraries/DHT/dht.cpp:78: multiple definition ofdht::read22(unsigned char)' dht.cpp.o:dht.cpp:78: first defined here DHT/dht.cpp.o: In function dht::read21(unsigned char)': /home/ubuntu/Arduino/libraries/DHT/dht.cpp:70: multiple definition ofdht::read21(unsigned char)' dht.cpp.o:dht.cpp:70: first defined here DHT/dht.cpp.o: In function dht::read11(unsigned char)': /home/ubuntu/Arduino/libraries/DHT/dht.cpp:42: multiple definition ofdht::read11(unsigned char)' dht.cpp.o:dht.cpp:42: first defined here /opt/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-sbrkr.o): In function _sbrk_r': sbrkr.c:(.text._sbrk_r+0xc): warning: undefined reference to_sbrk' collect2: ld returned 1 exit status
do you have the lib included twice? copied it to 2 locations? (sketch folder , library folder, arduino lib folder?)
