More of an update:
I added in batch of code that records how often the system is getting Checksum errors. I then left the system running while I went to sleep. Lo and Behold, the error rate is consistently 45%, and I'm frequently getting abberant readings of ~55f (~12c). The room is clearly not that cold.
I know you're not supposed to check the sensor more often than every 2 seconds. I rewrote robtillaart's code a little bit (Which is like having a 4th grader trying to follow Da Vinci, his code is much more succinct):
#include <dht.h>
#include "ERxPachube.h"
#include <Ethernet.h>
#include <SPI.h>
dht DHT;
#define DHT22_PIN 7
byte mac[] = {
0x90, 0xA2, 0xDA, 0x00, 0x21, 0xE3 };
byte ip[] = {
192, 168, 1, 20 }; // no DHCP so we set our own IP address
float TempC = 0;
float Humidity = 0;
float TempF = 0;
float OldTemp = 0;
float OldHumidity = 0;
float error = 0;
float run = 0;
float errorPerc = 0;
#define PACHUBE_API_KEY "Your API Here" // fill in your API key PACHUBE_API_KEY
#define PACHUBE_FEED_ID 34665 // fill in your feed id
ERxPachubeDataOut dataout(PACHUBE_API_KEY, PACHUBE_FEED_ID);
void PrintDataStream(const ERxPachube& pachube);
Ethernet.begin(mac, ip);
dataout.addData(0);
dataout.addData(1);
dataout.addData(2);
dataout.addData(3);
Serial.println("+++++++++++++++++++++++++++++++++++++++++++++++++");
float fSensorData = 15.23;
int chk = DHT.read22(DHT22_PIN);
delay(10000);
switch (chk)
case 0:
Serial.print("OK,\t");
TempC = DHT.temperature;
//Humidity = DHT.humidity;
case -1:
Serial.print("Checksum error,\t");
error = error +1;
case -2:
Serial.print("Time out error,\t");
default:
Serial.print("Unknown error,\t");
TempF = float((TempC * float(1.8))+32);
if (TempF > 150)
TempF = OldTemp;
delay(20000);
int chk2 = DHT.read22(DHT22_PIN);
delay(10000);
switch (chk2)
case 0:
//TempC = DHT.temperature;
case -1:
error = error + 1;
case -2:
default:
if (Humidity > 101)
Humidity = OldHumidity;
dataout.updateData(0, analogRead(0));
dataout.updateData(1, analogRead(1));
dataout.updateData(2, TempF);
dataout.updateData(3, Humidity);
int status = dataout.updatePachube();
Serial.print("sync status code <OK == 200> => ");
Serial.println(status);
PrintDataStream(dataout);
if (TempF < 150)
OldTemp = TempF;
if (Humidity < 101)
OldHumidity = Humidity;
run = run+2;
errorPerc = error / run;
Serial.print(errorPerc);
Serial.println("% errors");
delay(20000);
unsigned int count = pachube.countDatastreams();
Serial.print("data count=> ");
Serial.println(count);
Serial.println("<id>,<value>");
for(unsigned int i = 0; i < count; i++)
Serial.print(pachube.getIdByIndex(i));
Serial.print(",");
Serial.print(pachube.getValueByIndex(i));
I'm trying to send information my environmental conditions to Pachube every minute. That's the goal.
I'm wondering about the requests to the sensor. The
and subsequent "case" check, is that a request from the sensor?
When I'm asking the sensor for the current humidity and temperature, are those two different requests? Should I space these out as much as possible? (This is what I did in the code above).
Or does the
request call all the sensor information, and load it into the Arduino memory, waiting for the DHT.temperature and DHT.humidity calls?
Does anyone else have a similar error rate? That's what I'm really trying to drive down.
