'class HardwareSerial' has no member named 'sprintf'
I HAVE THIS ISSUE AND I TRIED EVERYTHING PLEASE HELP
//7 RTC Tutorial
#include <U8glib.h> // OLED
#include <Wire.h> // I2C
#include <Time.h> // Time Manipulation
#include <DS1307RTC.h> // DS1307 RTC
char timebuf[10]; // Time
char datebuf[10]; // Date
int year2digit; // 2 digit year
int year4digit; // 4 digit year
void setup(void) {
void loop(void) {
tmElements_t tm;
if (RTC.read(tm)) {
year2digit = tm.Year - 30; // 2 digit year variable
// year4digit = tm.Year + 1970; // 4 digit year variable
Print;
delay(1000); // Delay of 1sec
void Print(){
Serial.sprintf(timebuf, "%02d:%02d:%02d",tm.Hour, tm.Minute, tm.Second ); // format time
Serial.sprintf(datebuf, "%02d/%02d/%02d",tm.Day, tm.Month, year2digit ); // format date
sprintf prints to a string buffer, so it isn't surprising that Serial doesn't implement it.
Serial does, however, implement a method to print the contents of a string buffer, called "print".
Please get into the habit of using code tags when posting code.
houssienmortada:
Try as hard as you may, sprintf will never work with HardwareSerial because H.S. has no function (member) with that name.
I think what you want to do is THIS:
int hours = 4;
int mins = 34;
char buffer [64]; // must be large enough for your whole string!
sprintf (buffer, "The time is HOURS: %02d, MINUTES: %02d", hours, mins).
Serial.print (buffer);
Will result in:
[b]The time is HOURS: 04, MINUTES: 34
[/b]
Hope this helps.
You seem to be missing the command
which goes in the setup section, which is currently empty.
Whatever other problems you have, if any, Serial won't do anything until it is initialised.
