CLASS INFORMATION
I am using an uno with 1.5.6 and I have a question about my code, i am trying to have the Serial print out a 2d array of 0’s and using a function change the numbers in the array. I have tried using nested for loops with arrays, but they take up to much memory so i am going with a class attempt
class enter{
  private:
  int right;
  int left;
  public:
  enter(){
  enter(int y,int x){
    right=y;
    left=x;
  int getRight(){
    return right;
  int getLeft(){
   return left;
  boolean check(int y,int x){//checks where the point is
    if(right==y&&left==x){
     return true;
    else{
     return false;
Serial.begin(9600);  // put your setup code here, to run once:
    for (int p = 0; p < 10; p++) {
    for (int i = 0; i < 15; i++) {
      //  client.print(array[p][i]);
      //  client.print("|");
     Serial.print("0");
     Serial.print("|");
    //client.println("
  Serial.println("break");
  enter b(2,3);// says there is a 4 at point 2,3
     if(b.check(p,i)){
         Serial.print("4");
         Serial.print("|");
     else{
      Serial.print("0");
      Serial.print("|");
    //client.println("
  Serial.println("done");
The issue i am having is that i do not know how this would work with a variable number of enter objects, which is my intended goal, are there any solutions to my problem or should i try another approach at this.
