Class members default initialization methods
Hello!
I am reading about constructors and different ways to initialize class member variables within the constructors. There is a nice summary from anon46966594 in this thread: Best practice when initialising class variables - #10 by Boffin, which I rewrite below:
Using “this” keyword:
foo(int bar1, int bar2, int bar3)
this->bar1=bar1;
this->bar2=bar2;
this->bar3=bar3;
Using “” or 'm' for member variables:
m_bar1=bar1;
m_bar2=bar2;
m_bar3=bar3;
Using member initializer list:
: bar1(bar1), bar2(bar2), bar3(bar3)
However, I am unclear about assigning default values for these different methods.
I have tried this (I will paste the full code below):
Person(){}
Person(int age);
Person(int age , int size = 11);
It compiles if I create an object with two arguments (ie Jack 33, 45), but will give an error (call of overloaded 'Person(int)' is ambiguous Person jack (33)) if I use only one parameter, expecting the program to assign the default value to the size variable.
I have been looking around for some examples and found this library which sort of confused me even further (it’s a pushbutton library from github: pushButton/pushButton.h at main · italo-coelho/pushButton · GitHub)
In the H file the code is:
public:
pushButton(uint8_t pin);
pushButton(uint8_t pin, uint16_t debounce, uint8_t pin_mode = PIN_MODE);
in the CPP files the constructors are:
pushButton::pushButton(uint8_t pin)
_pin = pin;
_pinMode = PIN_MODE;
_debounce = DEBOUNCE;
pinMode(_pin, _pinMode);
pushButton::pushButton(uint8_t pin, uint16_t debounce, uint8_t pin_mode)
_pin = pin;
_pinMode = pin_mode;
_debounce = debounce;
So the PIN_MODE default value is not there anymore in the CPP file (why?). Also this code uses the same method that I use in my code to assign default value to a variable, but my code would not compile (with “= 33” added to the size argument).
my full code is the one below:
class Person{
 private:
   int _age;
   int _size;
 public:
 Person(){}
 Person(int age);
 Person(int age , int size);
 // Person(int age , int size = 11);  the code wouldnot compile with this line in place of the one above
Person::Person(int age){
 _age = age;
 Serial.print("Person age: "); Serial.println(_age);
 Serial.print("Person size: "); Serial.println(_size);
Person::Person(int age , int size){
 _age = age;
 _size = size;
Person john(55, 55);
Person jack (33);
I see... :slightly_smiling_face:
Thanks a lot !!
The delegated constructor seems to be a much better way of doing it , brilliant! :smiley:
In regard to the library I quoted, is it normal to have initialized the argument only in the H file and not in the CPP file?
Fantastic! will paste your comments in my C++ note book :smiley:
