Class Object as Variable
Hi everyone,
this is my first post so I hope I follow all Forum rules correctly!
I have a code where I need to find the minimum and maximum of a Circular Buffer. I use the CircularBuffer lib
here is a part of my code:
 #include <CircularBuffer.h>
 CircularBuffer<float, 100> pressureBuffer;
 CircularBuffer<float, 100> temperatureBuffer;
 CircularBuffer<float, 100> humidityBuffer;
 for (int i = 0; i <= pressureBuffer.size(); i++)
   if (pressureBuffer[i] > max)
     max = pressureBuffer[i] + 5;
   if (pressureBuffer[i] < min)
     min = pressureBuffer[i] - 5;
as you see I have three CircularBuffer variables. Now my question is: how can I use the CB variable for a function? something like
 int findMin(anyBuffer)
   for (int i = 0; i <= anyBuffer.size(); i++)
     if (anyBuffer[i] < min)
       min = anyBuffer[i] - 5;
  return min;
thx in advance!
Why "<=" ?
Welcome
And you can do something like this : int findMin( CircularBuffer<float, 100> const &anyBuffer )
That was just a Typo I think. Of course it should be "<". Thanks for the correction!
Thank you very much. That worked as expected. I did not know that I had to refer to the class again in the function argument and tried to handle it like a "normal" variable. One question: Why would you use const in this context?
Because your findMin() function doesn't need to modify data in the buffer.
Typos are usually one-offs.
Yeah I don't know what happended there. I think I copied it from the example of CircularBuffer. Yet in the example it is < not <=. No clue. But thanks again for correcting!
Does that have any advantage for the program or just for me that I don't modify the Buffer by mistake?
