'class RTC_DS1307' has no member named 'begin'
Questo è il mio programma:
#include "RTClib.h"
#include <SD.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <Adafruit_Thermal.h>
#include <LiquidCrystal.h>
#include <SD.h>
#define LOG_INTERVAL  1000 // mills between entries
#define ECHO_TO_SERIAL   1 // echo data to serial port
#define WAIT_TO_START    0 // Wait for serial input in setup()
#define SYNC_INTERVAL 1000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
RTC_DS1307 RTC; // define the Real Time Clock object
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
void error(char *str)
  Serial.print("error: ");
  Serial.println(str);
  while(1);
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
int printer_RX_Pin = 8;  // this is the green wire
int printer_TX_Pin = 9;  // this is the yellow wire
Adafruit_Thermal printer(printer_RX_Pin, printer_TX_Pin);
  Serial.begin(1200);
  lcd.begin(20,4);
  printer.begin();
#if WAIT_TO_START
  Serial.println("Type any character to start");
  while (!Serial.available());
#endif //WAIT_TO_START
  Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin(chipSelect)) {
    error("Card failed, or not present");
  Serial.println("card initialized.");
  // create a new file
  char filename[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i/10 + '0';
    filename[7] = i%10 + '0';
    if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      break;  // leave the loop!
  if (! logfile) {
    error("couldnt create file");
  Serial.print("Logging to: ");
  Serial.println(filename);
  Wire.begin();
  if (!RTC.begin()) {
    logfile.println("RTC failed");
#if ECHO_TO_SERIAL
    Serial.println("RTC failed");
#endif  //ECHO_TO_SERIAL
  logfile.println("millis,time,light,temp");
#if ECHO_TO_SERIAL
    Serial.println("millis,time,light,temp");
#endif// ECHO_TO_SERIAL
  // If you want to set the aref to something other than 5v
  //analogReference(EXTERNAL);
String line = "";
  DateTime now;
  // delay for the amount of time we want between readings
  delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
  // log milliseconds since starting
  uint32_t m = millis();
  logfile.print(m);           // milliseconds since start
  logfile.print(", ");
#if ECHO_TO_SERIAL
  Serial.print(m);         // milliseconds since start
  Serial.print(", ");
#endif
  // fetch the time
  now = RTC.now();
  // log time
  logfile.print(now.unixtime()); // seconds since 2000
  logfile.print(now.year(), DEC);
  logfile.print("/");
  logfile.print(now.month(), DEC);
  logfile.print("/");
  logfile.print(now.day(), DEC);
  logfile.print(" ");
  logfile.print(now.hour(), DEC);
  logfile.print(":");
  logfile.print(now.minute(), DEC);
  logfile.print(":");
  logfile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
  Serial.print(now.unixtime()); // seconds since 2000
  Serial.print(", ");
  Serial.print(now.year(), DEC);
  Serial.print("/");
  Serial.print(now.month(), DEC);
  Serial.print("/");
  Serial.print(now.day(), DEC);
  Serial.print(" ");
  Serial.print(now.hour(), DEC);
  Serial.print(":");
  Serial.print(now.minute(), DEC);
  Serial.print(":");
  Serial.print(now.second(), DEC);
  //File dataFile = SD.open("datalog.txt", FILE_WRITE);
  if (Serial.available()) {
    char inByte = Serial.read();
    switch (inByte) {
      case '\n':
        lcd.setCursor(0,0);
        lcd.print(line);
        printer.println(line);
        // if the file is available, write to it:
        logfile.print(line);
#if ECHO_TO_SERIAL
        Serial.println(line);     //print complete line
        line = "";                    //reset to empty string
    default:
        line += inByte;           //append inByte to the line String
  if ((millis() - syncTime) < SYNC_INTERVAL) return;
  syncTime = millis();
  logfile.flush();
L’ho implementato copiando pari pari delle parti da un programma di esempio. Stessa path dove si trovano i pde, stesse librerie usate… l’esempio compila il mio no! Mi dice ‘class RTC_DS1307’ has no member named ‘begin’. Perchèèèèè??? Son 3 ore che ci vado dietro ma non capisco perchè!?
Questo è l’esempio:
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
// A simple data logger for the Arduino analog pins
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL  1000 // mills between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk
// set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to
// the last 10 reads if power is lost but it uses less power and is much faster!
// the digital pins that connect to the LEDs
#define redLEDpin 2
#define greenLEDpin 3
// The analog pins that connect to the sensors
#define photocellPin 0           // analog 0
#define tempPin 1                // analog 1
#define BANDGAPREF 14            // special indicator that we want to measure the bandgap
#define aref_voltage 3.3         // we tie 3.3V to ARef and measure it with a multimeter!
#define bandgap_voltage 1.1      // this is not super guaranteed but its not -too- off
// the logging file
File logfile;
  // red LED indicates error
  digitalWrite(redLEDpin, HIGH);
  while(1);
void setup(void)
  // use debugging LEDs
  pinMode(redLEDpin, OUTPUT);
  pinMode(greenLEDpin, OUTPUT);
#if WAIT_TO_START
  // initialize the SD card
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  // see if the card is present and can be initialized:
  if (! logfile) {
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) {
#if ECHO_TO_SERIAL
  logfile.println("millis,stamp,datetime,light,temp,vcc");
#if ECHO_TO_SERIAL
  Serial.println("millis,stamp,datetime,light,temp,vcc");
void loop(void)
  DateTime now;
  digitalWrite(greenLEDpin, HIGH);
#if ECHO_TO_SERIAL
  Serial.print(", ");
#endif
  // fetch the time
  now = RTC.now();
  // log time
  logfile.print(now.unixtime()); // seconds since 1/1/1970
  logfile.print('"');
  logfile.print("/");
  logfile.print("/");
  logfile.print(" ");
  logfile.print(":");
  logfile.print(":");
  logfile.print('"');
#if ECHO_TO_SERIAL
  Serial.print(now.unixtime()); // seconds since 1/1/1970
  Serial.print(", ");
  Serial.print('"');
  Serial.print("/");
  Serial.print("/");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
  Serial.print('"');
  analogRead(photocellPin);
  delay(10);
  int photocellReading = analogRead(photocellPin);
  analogRead(tempPin);
  delay(10);
  int tempReading = analogRead(tempPin);
  // converting that reading to voltage, for 3.3v arduino use 3.3, for 5.0, use 5.0
  float voltage = tempReading * aref_voltage / 1024;
  float temperatureC = (voltage - 0.5) * 100 ;
  float temperatureF = (temperatureC * 9 / 5) + 32;
  logfile.print(photocellReading);
  logfile.print(temperatureF);
#if ECHO_TO_SERIAL
  Serial.print(", ");
  Serial.print(photocellReading);
  Serial.print(", ");
  Serial.print(temperatureF);
  // Log the estimated 'VCC' voltage by measuring the internal 1.1v ref
  analogRead(BANDGAPREF);
  delay(10);
  int refReading = analogRead(BANDGAPREF);
  float supplyvoltage = (bandgap_voltage * 1024) / refReading;
  logfile.print(supplyvoltage);
#if ECHO_TO_SERIAL
  Serial.print(", ");
  Serial.print(supplyvoltage);
#endif // ECHO_TO_SERIAL
  logfile.println();
#if ECHO_TO_SERIAL
  digitalWrite(greenLEDpin, LOW);
  // Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
  // which uses a bunch of power and takes time
  // blink LED to show we are syncing data to the card & updating FAT!
  logfile.flush();
  digitalWrite(redLEDpin, LOW);
Ciao, metti un titolo più adeguato al Topic, le frasi ad effetto servono solo a chi le scrive ;)
uhm, se risolvi fammi sapere!
riportava anche a me questo errore. poi, stanco, ho deciso di comunicare con il DS1307 a mano, inviando i comandi direttamente con il Wire!
Intanto se l'esempio compila ed il tuo no, non l'hai copiato pari pari ma hai apportato qualche modifica ;) Poi vedo ad esempio che includi 2 volte la libreria SD.h.
Poi con che IDE stai compilando? Hai visto se la RTCLib è compatibile con l'IDE che stai usando?
Prova a compilare eliminando tutte le lib "extra" così si vede se non ci sia qualche conflitto; altra cosa: stai lavorando direttamente su Arduino o su un qualche chip in stand-alone?
Piccola svista :) cancellata ma non cambia nulla...
Uso IDE 1.0, ho provato anche con IDE 1.0.1 ma niente da fare. La RTClib l'ho usata anche in molti altri codici, mai dato problemi. Ma ti dico, quello che proprio non capisco, a parte ovviamente come dici tu il fatto di aver modificato qualche cosine ;) è che se guardi, la parte iniziale, fino al comando if (!RTC.begin()) { ovvero il comando incriminato, è identica! :~
Provato... niente da fare...
Arduino UNO col suo chip originale e shield http://www.adafruit.com/products/243. Mi da problemi gia solo in verifica.
e se togli lo shield e la relativa lib?
Non credo dia fastidio lo shield perchè non ho neanche collegato arduino al pc, ho solamente fatto la verifica. Togliendo le librerie e le parti relative va... ma l'esempio con relative librerie funziona però, senza nessun problema.
Parti dall'esempio ed aggiungi un componente per volta, se arrivi a mettere tutto senza errori ti basta sostituire/modificare lo sketch
E' quello che sto facendo ]:D Adesso ti dico... :D
9six4: E' quello che sto facendo ]:D Adesso ti dico... :D
scusa, era solo per darti un suggerimento, non dubito che te la cavi da solo, ci mancherebbe :) ma alle volte uno segue una sua idea fissa e non pensa alle cose più sceme, mentre io che sono scemo non so pensare ad altro, ecco il perché dei mei suggerimenti del zzz :D
No Michele mi hai frainteso, il diavoletto l'ho messo perchè stavo facendo una furbata per aggirare il problema, non ti fare problemi figurati, anzi, hai ragione, a volte sono le cavolate a creare i problemi più grossi. Comunque, tornando al problema fatto... e... COMPILA!!! XD Mistero da 100 punti! Perchè su una pagina compila e una no??? Stessa posizione, stesso IDE, stesse librerie, tutto identico, uno va e uno no! Misteroooooo!
Fammi capire, tu hai fatto una copia SOLO di alcune parti dell'esempio? Se è così penso che tu abbia solo omesso di copiare una qualche riga fondamentale. L'esempio quindi è molto più complesso del tuo sketch, se ho ben capito, se compila lui questa è la conferma che manca semplicemente qualcosa. Prova a recuperare tutti i riferimenti al DS1307 oppure, sempre con la prova dello scemo (che sarei sempre io), riparti dall'esempio ed elimina una cosa per volta facendo sempre la verifica, è da squilibrati ma si arriva di sicuro ad un punto certo :)
Non è che l'include della RTClib vada dopo quello della Wire, visto che la prima dipende dalla seconda?
@ Michele, ho provato,tra l'altro poi ho cancellato tutto ciò che non mi serviva fino a che il secondo codice è divendato identico al primo. Uno compila, l'altro no! Mistero! :~
@dancol90, ho provato, niente da fare, non compila neanche nello stesso ordine.
9six4: @ Michele, ho provato,tra l'altro poi ho cancellato tutto ciò che non mi serviva fino a che il secondo codice è divendato identico al primo. Uno compila, l'altro no! Mistero! :~
Scusami, o non capisco o mi sono spiegato una mrd :disappointed_relieved: Io avrei fatto così: parto dall'esempio funzionante e ne elimino un pezzo alla volta, e per ogni pezzo eliminato faccio la compilazione, se la compilazione è ok tolgo un altro pezzo e ripeto la compilazione; se invece la compilazione mi dà errore so che quel pezzo devo lasciarlo, almeno temporaneamente nello sketch. Alla fine arrivo ad uno sketch dimagrito ma funzionante. Ora siccome l'esempio non ha tutte le lib e lo shield tuoi, dovresti partire dall'esempio completo, aggiungere subito shield e lib tue e fare una compilazione, perché se già ti dà errore c'è un conflitto, se non te ne dà invece procedi come detto. La facciamo questa prova? o hai già fatto proprio così e non ho capito niente io?
Michele è proprio quello che ho fatto :) Sono partito dall'esempio funzionante ed ho tolto man mano le parti che non mi servivano verificando ogni volta che compilasse. Una volta tolto tutto ciò che non mi serviva ho iniziato ad aggiungere le parti del mio codice che mi servivano, controllando sempre che compilasse. Alla fine ho ottenuto che i due codici fossero completamente identici! Uno compilava uno no, ed il perchè proprio non lo capisco.
9six4: Michele è proprio quello che ho fatto :) Sono partito dall'esempio funzionante ed ho tolto man mano le parti che non mi servivano verificando ogni volta che compilasse. Una volta tolto tutto ciò che non mi serviva ho iniziato ad aggiungere le parti del mio codice che mi servivano, controllando sempre che compilasse. Alla fine ho ottenuto che i due codici fossero completamente identici! Uno compilava uno no, ed il perchè proprio non lo capisco.
Beh, identici no.... altrimenti ti basterebe cancellare quello che non compila ed usare quello che compila no? ;)
@9six4: ho provato a compilare il tuo sketch, e anche a me da il tuo stesso errore. Mi è bastato cambiare questo:
#include "RTClib.h"
#include <SD.h>
#include <Wire.h>
in questo:
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
che è in definitiva quello che ti dicevo qualche post sopra, e compila senza problemi.
