Hello!
I'm stuck with Processing. I had a simple project where I toggle RGB-buttons, I uploaded it to my Android phone, it worked.
I did some editing on it now I can't upload anymore. Realised it gave me an error message
class "Serial" does not exist
import processing.serial.*;
Serial myPort;
Serial is underlined with red.
I used a simple Sketch, can't upload this either.
Here the code for the sketch
Serial myPort;
String portName = Serial.list()[2];
myPort = new Serial(this, portName, 9600);
void draw() {
if (keyPressed) {
if (key=='r' || key=='R'){
fill(0); //fill 0 = svart
myPort.write(114);
delay (1000);
if (key=='g' || key=='G'){
myPort.write(103);
delay (1000);
if (key=='b' || key=='B'){
myPort.write(103);
delay (1000);
fill(255); //fill 255=white
rect(25,25,50,50); //25x25 square in 50 by 50 palette
Here's the error message:
No library found for processing.serial
[mkdir] Created dir: /var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/bin
[echo] org.eclipse.jdt.core.JDTCompilerAdapter
-set-mode-check:
-set-debug-files:
-check-env:
Android SDK Tools Revision 25.2.3
Installed at /Users/AZMI/Documents/Arduino/android-sdk-macosx
-setup:
[echo] Project Name: RGB_SimpleWrite
Project Type: Application
-set-debug-mode:
-debug-obfuscation-check:
-pre-build:
-build-setup:
Using latest Build Tools: 23.0.1
[echo] Resolving Build Target for RGB_SimpleWrite...
Project Target: Android 6.0
API level: 23
[echo] ----------
[echo] Creating output directories if needed...
[mkdir] Created dir: /var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/bin/res
[mkdir] Created dir: /var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/bin/rsObj
[mkdir] Created dir: /var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/bin/rsLibs
[mkdir] Created dir: /var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/gen
[mkdir] Created dir: /var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/bin/classes
[mkdir] Created dir: /var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/bin/dexedLibs
[echo] ----------
[echo] Resolving Dependencies for RGB_SimpleWrite...
Library dependencies:
No Libraries
[echo] ----------
[echo] Building Libraries with 'debug'...
[subant] No sub-builds to iterate on
-code-gen:
Merging AndroidManifest files into one.
Manifest merger disabled. Using project manifest only.
[echo] Handling aidl files...
No AIDL files to compile.
[echo] ----------
[echo] Handling RenderScript files...
[echo] ----------
[echo] Handling Resources...
Generating resource IDs...
[echo] ----------
[echo] Handling BuildConfig class...
Generating BuildConfig class.
-pre-compile:
-compile:
[javac] Compiling 4 source files to /var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/bin/classes
1. WARNING in /private/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/src/processing/test/rgb_simplewrite/MainActivity.java (at line 11)
import android.support.v4.content.ContextCompat;
The import android.support.v4.content.ContextCompat is never used
2. WARNING in /private/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/src/processing/test/rgb_simplewrite/MainActivity.java (at line 15)
import android.Manifest;
The import android.Manifest is never used
3. WARNING in /private/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/src/processing/test/rgb_simplewrite/MainActivity.java (at line 49)
int check;
The value of the local variable check is not used
4. ERROR in /private/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/src/processing/test/rgb_simplewrite/RGB_SimpleWrite.java (at line 8)
The import processing.serial cannot be resolved
5. ERROR in /private/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/src/processing/test/rgb_simplewrite/RGB_SimpleWrite.java (at line 24)
Serial myPort;
Serial cannot be resolved to a type
6. ERROR in /private/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/src/processing/test/rgb_simplewrite/RGB_SimpleWrite.java (at line 29)
7. ERROR in /private/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/src/processing/test/rgb_simplewrite/RGB_SimpleWrite.java (at line 30)
8. ERROR in /private/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/src/processing/test/rgb_simplewrite/RGB_SimpleWrite.java (at line 30)
9. ERROR in /private/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/src/processing/test/rgb_simplewrite/RGB_SimpleWrite.java (at line 41)
myPort.write(114);
10. ERROR in /private/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/src/processing/test/rgb_simplewrite/RGB_SimpleWrite.java (at line 47)
myPort.write(103);
11. ERROR in /private/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/src/processing/test/rgb_simplewrite/RGB_SimpleWrite.java (at line 53)
myPort.write(103);
11 problems (8 errors, 3 warnings)
BUILD FAILED
/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/build.xml:15: The following error occurred while executing this line:
/var/folders/d4/mm8qyq_x3s14727yg7qw4mhr0000gn/T/android704940619117704727sketch/build.xml:28: Compile failed; see the compiler error output for details.
Total time: 2 seconds
What happend? What am I missing?
