class SPISettings error message
Hello world,
I have been working on this piece of code for the receiving end arduino which is an atmega328p using nRF24L01 transceivers. I had it sending and receiving pieces of data, adding more as I go along with testing inbetween. However, this error started popping up and for the life of me I dont know what it means.I Have no gone into or change anything in the SPI.h library, so I am unsure what might be causing it.
Here is the error message:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino Nano, ATmega328P"
In file included from C:\Users\justi\Desktop\BMP280 Receiv Test - Copy\bmp280test\bmp280test.ino:3:0:
C:\Users\justi\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.21\libraries\SPI\src/SPI.h:72:1: error: expected unqualified-id before 'class'
 class SPISettings {
C:\Users\justi\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.21\libraries\SPI\src/SPI.h:72:1: error: expected constructor, destructor, or type conversion before 'class'
exit status 1
Error compiling for board Arduino Nano.
option enabled in File -> Preferences.
Here is my code:
//TRANSCEIVER SETUP
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include <Wire.h>
const uint64_t pipeIn = 0xE8E8F0F0E1LL;
//const NRF24L01_EnableFeatureDynPL();
RF24 radio(9, 10);
struct MyData {
float readTemperature;
float readPressure;
float readAltitude;
float readSatellites;
float readLatitude;
float readLongitude;
//long readDate;
//long readTime;
float readSpeed;
MyData data;
void resetData() {
  data.readTemperature = 0;
  data.readPressure = 0;
  data.readAltitude = 0;
  data.readSatellites = 0;
  data.readLatitude = 0;
  data.readLongitude = 0;
//  data.readDate = 0;
//  data.readTime = 0;
  data.readSpeed = 0;
//LCD SETUP
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
int button = 8;
boolean state = HIGH;
int reading;
boolean previous;
long time = 0;
long debounce = 200;
radio.begin();
                        // radio.enableDynamicPayloads();
radio.setAutoAck(false);
radio.setDataRate(RF24_250KBPS);
radio.openReadingPipe(1,pipeIn);
radio.startListening();
  Serial.println(F("BMP280 test"));
//LCD**********************************************
  pinMode(button, INPUT);
  lcd.begin(20, 4);
  Serial.println(F("Waiting to receive"));
  resetData();
  while ( !radio.available() ) {
    // do nothing
  radio.read(&data, sizeof(MyData));
  Serial.print("Temperature = ");
  Serial.print(data.readTemperature);
  Serial.println(" *C");
  Serial.print("Pressure = ");
  Serial.print(data.readPressure);
  Serial.println(" Pa");
  Serial.print("Approx altitude = ");
  Serial.print(data.readAltitude);
  Serial.println(" m");
  Serial.println(data.readSatellites);
//LCD
  Serial.println(state);
  reading = digitalRead(button);
  if (reading == LOW && previous == HIGH) {
    delay(10);
    if (digitalRead(button) == LOW) state = !state;
  previous = reading;
 if (state == HIGH) {
  lcd.setCursor(0, 0);
  lcd.print("Longitude:");
    lcd.setCursor(10, 0);
    lcd.print(" #########");
  lcd.setCursor(0, 1);
  lcd.print("Latitude:");
    lcd.setCursor(9, 1);
  lcd.setCursor(0, 2);
  lcd.print("Altitude:");
    lcd.setCursor(9, 2);
    lcd.print(data.readAltitude);
    lcd.print("m");
  lcd.setCursor(0, 3);
  lcd.print("Satellites:");
    lcd.setCursor(11, 3);
    lcd.print("        #");
  if (state == LOW) {
  lcd.print("Temperature:");
    lcd.setCursor(12, 0);
    lcd.print(data.readTemperature);
  lcd.print("Pressure:");
    lcd.print(data.readPressure);
  lcd.print("Time:");
    lcd.setCursor(5, 2);
    lcd.print("       ########");
  lcd.print("Date:");
    lcd.setCursor(5, 3);
    lcd.print("     ##########");
This was compiling fine until I added the bits about satellite, latitude, longitude, and speed data that is being received from a transmitter. However, I tried removing them and going back to what worked before but the error persists. Any guidance would be appreciated, thank you
You are correct, my bad and thank you for pointing this out. I am still new to this so still learning these standards, feel pretty dumb now haha.
