Okay so, some sample code that was linked to a hackaday post im guessing is out of date. I new to programming and was hoping someone could help me (:
Errors:
sketch_jul22b.cpp: In function ‘void displayFrequency(long int)’:
sketch_jul22b:250: error: ‘class String’ has no member named ‘setArray’
sketch_jul22b:277: error: ‘class String’ has no member named ‘getArray’
Specific line:
lcdOutput.setArray(“108.0MHZ”); // Just a template…
I hope this is clear enough and that i have provided all the info that is needed. If you with to view the full sample code it can be found here…http://mikeyancey.com/files/arduino-fm/ARRduino_FM_v1/ARRduino_FM.pde … The only thing i knew i had to change, and have changed is TextString to String.
Thanks for the reply Rob, any suggestions for me to solve the problem? As i have litrally no experience with programming, any chance you or someone could have a look at the original code and give me some clues to fix the error?
I had no idea what class TextString was so went and had a look. Looks like it’s been replaced by String and String doesn’t have those two members, normally in that case I would look at the code for get/setArray in the old class, see what it does and see if there’s a member in the new class that does the same thing.
Unfortunately TextString doesn’t appear to have those members either so I don’t know where that code you have got them from.
I’ll have a look at your code and see if I can see what it’s doing and recommend a change.
