Hi all,
Im trying to run a simple code that scans all networks in the vicinity. Here is the code:
#include <WiFi.h>
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println("Setup done");
Serial.println("scan start");
// WiFi.scanNetworks will return the number of networks found
int n = WiFi.scanNetworks();
Serial.println("scan done");
if (n == 0) {
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
for (int i = 0; i < n; ++i) {
// Print SSID and RSSI for each network found
Serial.print(i + 1);
Serial.print(": ");
Serial.print(WiFi.SSID(i));
Serial.print(" (");
Serial.print(WiFi.RSSI(i));
Serial.print(")");
Serial.println((WiFi.encryptionType(i) == WIFI_AUTH_OPEN)?" ":"*");
delay(10);
Serial.println("");
// Wait a bit before scanning again
delay(5000);
Here is what I am getting during compilation:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Jesse DeRue\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=80,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=115200,DebugLevel=none -ide-version=10815 -build-path C:\Users\JESSED~1\AppData\Local\Temp\arduino_build_994689 -warnings=none -build-cache C:\Users\JESSED~1\AppData\Local\Temp\arduino_cache_449341 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.1 -prefs=runtime.tools.esptool_py-2.6.1.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.1 -prefs=runtime.tools.mkspiffs.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -verbose C:\Users\Jesse DeRue\AppData\Local\Temp\WiFiScan\WiFiScan.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Jesse DeRue\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=80,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=115200,DebugLevel=none -ide-version=10815 -build-path C:\Users\JESSED~1\AppData\Local\Temp\arduino_build_994689 -warnings=none -build-cache C:\Users\JESSED~1\AppData\Local\Temp\arduino_cache_449341 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.1 -prefs=runtime.tools.esptool_py-2.6.1.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.1 -prefs=runtime.tools.mkspiffs.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -verbose C:\Users\Jesse DeRue\AppData\Local\Temp\WiFiScan\WiFiScan.ino
Using board 'esp32' from platform in folder: C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4
Using core 'esp32' from platform in folder: C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4
Detecting libraries used...
"C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "C:\Users\JESSED~1\AppData\Local\Temp\arduino_build_994689\sketch\WiFiScan.ino.cpp" -o nul
Alternatives for WiFiEsp.h: [WiFiEsp-2.2.2@2.2.2]
ResolveLibrary(WiFiEsp.h)
-> candidates: [WiFiEsp-2.2.2@2.2.2]
"C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src" "C:\Users\JESSED~1\AppData\Local\Temp\arduino_build_994689\sketch\WiFiScan.ino.cpp" -o nul
"C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src" "C:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src\WiFiEsp.cpp" -o nul
"C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src" "C:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src\WiFiEspClient.cpp" -o nul
"C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src" "C:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src\WiFiEspServer.cpp" -o nul
"C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src" "C:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src\WiFiEspUdp.cpp" -o nul
"C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src" "C:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src\utility\EspDrv.cpp" -o nul
"C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src" "C:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src\utility\RingBuffer.cpp" -o nul
Generating function prototypes...
"C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src" "C:\Users\JESSED~1\AppData\Local\Temp\arduino_build_994689\sketch\WiFiScan.ino.cpp" -o "C:\Users\JESSED~1\AppData\Local\Temp\arduino_build_994689\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\JESSED~1\AppData\Local\Temp\arduino_build_994689\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/config" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_trace" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/app_update" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/asio" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bootloader_support" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/bt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/coap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/console" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/driver" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-tls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_adc_cal" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_event" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_client" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_http_server" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_https_ota" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp_ringbuf" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ethernet" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/expat" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fatfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freemodbus" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/freertos" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/heap" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/idf_test" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/jsmn" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/json" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/libsodium" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/log" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/lwip" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mbedtls" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mdns" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/micro-ecc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/mqtt" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/newlib" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nghttp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/nvs_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/openssl" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protobuf-c" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/protocomm" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/pthread" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/sdmmc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/smartconfig_ack" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/soc" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spi_flash" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/spiffs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcp_transport" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/tcpip_adapter" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/ulp" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/vfs" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wear_levelling" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wifi_provisioning" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/wpa_supplicant" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp32-camera" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/esp-face" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32" "-IC:\Users\Jesse DeRue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\variants\esp32" "-IC:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2\src" "C:\Users\JESSED~1\AppData\Local\Temp\arduino_build_994689\sketch\WiFiScan.ino.cpp" -o "C:\Users\JESSED~1\AppData\Local\Temp\arduino_build_994689\sketch\WiFiScan.ino.cpp.o"
C:\Users\Jesse DeRue\AppData\Local\Temp\WiFiScan\WiFiScan.ino: In function 'void setup()':
WiFiScan:13:10: error: 'class WiFiEspClass' has no member named 'mode'
WiFi.mode(WIFI_STA);
WiFiScan:13:15: error: 'WIFI_STA' was not declared in this scope
C:\Users\Jesse DeRue\AppData\Local\Temp\WiFiScan\WiFiScan.ino: In function 'void loop()':
WiFiScan:40:55: error: 'WIFI_AUTH_OPEN' was not declared in this scope
Serial.println((WiFi.encryptionType(i) == WIFI_AUTH_OPEN)?" ":"*");
Using library WiFiEsp-2.2.2 at version 2.2.2 in folder: C:\Program Files (x86)\Arduino\libraries\WiFiEsp-2.2.2
exit status 1
The last line is my issue. I'm sure its calling the wrong library but I'm not sure how to fix. Ive spent countless hours trying to get it to compile successfully. Ive gone as far as using REVO uninstaller to remove all traces of IDE and started all over with the same errors.
Board selected in IDE: ESP32 Dev Module
IDE Ver: 1.8.15
Any help would be greatful as I brought this device to connect to an ad-hoc network that will be an automation network for a greenhouse.
