Classic Obstacle Avoidance Robot - Please Help
Hey Arduino fans, i am completely new to Arduino and so far have only accomplished the small task of flashing 8 LEDs in certain formations, but now its time for the big stuff.
My goal is to build the classic obstacle avoidance robot with the following servos and sensor:
https://www.sparkfun.com/products/9347 (X2)
https://www.sparkfun.com/products/9065 (For the sensor)
https://www.sparkfun.com/products/242 (The sensor)
In the attached files i have included the code i want to use for my robot, this is not my code i found it on another forum page, but it looks like a safe bet and is very straight forward. I do not know how else to attach the code so that it is inside that scroll box thingy help appreciated. Although because i want to be creative-ish; the twist that i want to add to my bot is a 3-axis gyro most likely this one (Triple-Axis Digital-Output Gyro ITG-3200 Breakout - SEN-09801 - SparkFun Electronics) suggestions welcome. This will control the two servos while driving to keep the bot stable and balanced and avoid the dreaded third wheel stabilizer thingy. Only problem is i have no idea how to adjust my code for this and actual circuit suggestions would help as well.
Thanks for taking a look at my post!
#include <Servo.h> //include Servo library
const int RForward = 0;
const int RBackward = 180;
const int LForward = RBackward;
const int LBackward = RForward;
const int RNeutral = 90;
const int LNeutral = 90; //constants for motor speed
const int pingPin = 7;
const int irPin = 0;  //Sharp infrared sensor pin
const int dangerThresh = 10; //threshold for obstacles (in cm)
int leftDistance, rightDistance; //distances on either side
Servo panMotor;
Servo leftMotor;
Servo rightMotor; //declare motors
long duration; //time it takes to recieve PING))) signal
  rightMotor.attach(11);
  leftMotor.attach(10);
  panMotor.attach(6); //attach motors to proper pins
  panMotor.write(90); //set PING))) pan to center
  int distanceFwd = ping();
  if (distanceFwd>dangerThresh) //if path is clear
    leftMotor.write(LForward);
    rightMotor.write(RForward); //move forward
  else //if path is blocked
    leftMotor.write(LNeutral);
    rightMotor.write(RNeutral);
    panMotor.write(0);
    rightDistance = ping(); //scan to the right
    panMotor.write(180);
    delay(700);
    leftDistance = ping(); //scan to the left
    panMotor.write(90); //return to center
    delay(100);
    compareDistance();
void compareDistance()
  if (leftDistance>rightDistance) //if left is less obstructed
    leftMotor.write(LBackward);
    rightMotor.write(RForward); //turn left
  else if (rightDistance>leftDistance) //if right is less obstructed
    rightMotor.write(RBackward); //turn right
   else //if they are equally obstructed
    rightMotor.write(RBackward); //turn 180 degrees
long ping()
  // Send out PING))) signal pulse
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  //Get duration it takes to receive echo
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  //Convert duration into distance
  return duration / 29 / 2;
oh thats how
sketch_aug25a.ino (2.15 KB)
If you're hoping to make some kind some kind of self-balancing platform, you may as well chuck that code in the bin; you're not going to be able to respond quickly enough with all those "delay()"s in the code.
JD150:
IMO you don't adjust an existing 'bot to make it balance - you develop a 'bot that can balance, and then add on the navigation and sensing logic, which is likely to be complex in its own right but much less time-critical. This strikes me as combining two relatively advanced projects and I suggest you think of this as the long term goal that you work towards starting from some much simpler projects such as getting your proximity sensor working, developing a stable 2wd 'bot that you can move and steer, and then developing that into something that can avoid obstacles and navigate however you want. By the time you have developed all that for yourself you will be in a position to understand how difficult it will be to develop a balancing bot, and the hardware involved, and decide whether you're ready to tackle that yet.
